The crossover frequency in my DIY speakers is calculated at 3000hz but still I can hear lots of sounds coming out from the tweeter that are supposed to be below the 3000 Hz range (according to charts like this one http://www.soundinstitute.com/images/tt58f2.gif ), like alto and even tenor sax or human voices. Isn't it there something wrong?? or this is normal and I should not use those charts as a reference. Many thanks Antonio |
#2 |
Did it Himself
How about you tell use more info like what slope you have used, and circuit diagram.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
This is the circuit diagram: http://www.diyaudio.com/forums/attac...amp=1150796093 My aim is just to copy it. At the moment I am using slightly different resistors values because I could not find the exact ones yet but I suppose this should not be the problem. I am using 3.3 ohms for R2 y 8.2 ohms for R1 instead of 3 and 8 ohms. Antonio |
#4 |
that chart gives fundamental tones, but tweeters mostly reproduce overtones...
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#5 |
Did it Himself
Are you using the same drivers as in the diagram?
#6 | ||
Hi Thanks for your replies.
Also now that I learned about cutoff and slopes it makes even more sense to hear a voice or a tenor sax sound coming out from the tweeter. Quote:
By the way the designer (Jim Griffin) said in another thread that the slope is high order (I do not how high) and that the design incorporates BSC. Thanks Antonio |
#7 |
Did it Himself
Well remember that the filter is not a brick wall and that even 10dB down sounds could be audible.
#8 |
Yes, you are right thanks.
I was a bit concerned because I did not what to blow up the ribbon tweeters. I have checked that the crossover connections are correct, so everything should be fine. Regards Antonio |
#9 |
My tweeters are playing the top of voices too
#10 |
Maybe you need to play just a little with both attenuation resistors ?
| Crossover for vifa 2 way setup - how can I find out what this crossover is doing? | Tino | Multi-Way | 11 | 17th May 2009 04:21 AM |
| Help me with a crossover. | raypalmer | Multi-Way | 4 | 5th April 2009 01:48 AM |
| Passive crossover into active crossover | hahfran | Multi-Way | 16 | 10th February 2008 06:16 PM |
| Crossover help please :) | Tenson | Multi-Way | 17 | 15th April 2006 09:34 AM |
| Can you hear the crossover point of a speaker with a well-designed crossover? | 454Casull | Multi-Way | 11 | 2nd April 2004 05:48 AM |
| Page generated in 0.10125 seconds (82.31% PHP - 17.69% MySQL) with 10 queries |
