Consensus Project
I agree with Pete. The P13WH is a VERY good mid driver, but it looses all that mid niceness if you ask it to do too much bass.
Far better to use it in a 3-way design where it will just do mid duties.
The XT tweeter is also a VERY nice tweeter, but you have to stay away from its res freq or put a whooping LCR circuit on it. The proposed series x-o does neither.
Re: yes are not good for bass
PeteMcK said:
The P13s are very good drivers, just not good at bass... /B]
Stee said:
... this idea about double bass effect is rubbish
I have to agree, if we mean to get lower NORMAL bass.
One 5 inch ( 130 mm ) will never make more than small monitor bass sound.
VIFA small woofers, mid woofers, are good in quality
and especially very good in Performance/Price comparison.
Double, TWO 130 mm woofers will not change towards the lower bass.
It can however reduce the midrange distortion.
As each woofer makes 50% of the sound only.
