Old 20th August 2008, 02:58 AM   #1
Default True qts values for Dayton RS 150 & 180
Has anyone measured these drivers to get accurate parameters. These drivers seemed to be the perfect solution for a mid size floor standing speaker that I am designing when using the web page values which are considerably lower than those listed on the PDF spec sheets.
Does anyone know what the true values are?
Old 20th August 2008, 02:33 PM   #2
Fosti is offline Fosti  Germany
Fosti's Avatar
Here's one for the RS180S (sorry, it's German):
http://hifi-selbstbau.de/index.php?o...d=38&Itemid=58
And here the RS150S is included:
http://www.zaphaudio.com/5.5test/compare.html
There's one for the RS180S here, too:
http://www.zaphaudio.com/6.5test/compare.html
"... they don't know what they do." - Thats right, quite often!
"... they don't do what they know." - That's right, even more often!!!
Old 20th August 2008, 04:14 PM   #3
Thanks for the links Fosti. I knew that Zaph had measured some of these drivers but for some reason I could not find the pages on the website. I guess these drivers will not work for me. Too bad because they are supposed to be very good in the low bass which is were I need them.
It looks as if the sensitivity ratings are pretty misleading too as they are rated as the 180 is rated as an 88 db driver. Only if averaging in the unusable range can this be concluded.
Peerless XXLS vs. Dayton Reference vs. Dayton Titanic MKIII ? wigginjs Multi-Way 6 3rd March 2008 08:56 PM
Vifa/Dayton/Dayton... First speaker for me, finally! alexcd Multi-Way 6 29th November 2006 10:54 PM
Dayton DA aluminum cone woofer + Dayton DC28f tweeter springy101 Multi-Way 7 15th March 2006 05:22 PM
Dayton 6" reference and dayton silk dome tweeter combo project...input? nerd of nerds Multi-Way 4 2nd December 2004 05:36 PM
Dayton 5.25" AL vs. Dayton 5.25 paper for Lo-Mid opinions? netgeek Multi-Way 6 14th May 2004 01:14 PM
Page generated in 0.05900 seconds (82.22% PHP - 17.78% MySQL) with 10 queries
