I just bought a pair of Magnavox 8WR speakers as a whim, they cost me a dollar.
I have in the shed a panel of MDF 1220 X 450 and enough scrap to add wings about 300 deep. I also have 2 pair of "Jaycar" 12 inch paper cone woofers, I know that the stated power handling of the Jaycars is optimistic but the Magnavox will probably take 15-20 watts if I remove some of the bass and send most of the LF to the 12 inch woofers. I am actually surprised at how nice the Magnavox sound even if a little ragged. As a dedicated mid they may sound a little better. I'm asking for a little help with a simple crossover to suit this combination of drivers and baffle. They will be a gift for friends and I have spent as much as I can really afford so I'm hoping I can use what have in stock as far as inductors and caps go. Will a second order at around 200 be OK???
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#2 |
I've also toyed with a pair of 16ohm 8WR's.
Wanting a bit more sparkle, I added a piezo supertweeter, using a cap for a 1st order XO. I used an L-pad on the piezo. No too bad. cheers Doug PS, did you see the 8WR's in the open-rear cabinet on fleaBay?
A speaker-builder's parable: "That burned down, fell over, then sank into the swamp. But the fourth one stayed up. And that's what you're going to get, Lad, the strongest castle of all." |
#3 | |
cgi.ebay.com.au/Vintage-Wooden-Floor-standing-Speakers-Magnavox-8WR_W0QQitemZ230281979740QQihZ013QQcategoryZ14990Q QssPageNameZWDVWQQrdZ1QQcmdZViewItem Follow the link on the eBay page and you can get a dimensioned picture of the cabinets. cheers Doug
#4 |
Hi Doug, these were in a small 19litre sealed box and they are the 8Ohm version, I'll add a super tweeter if I need to.
These were from Ebay but pick-up in Melbourne
#5 |
Doug I just followed thru on that link, mine are same but slightly newer vintage, what do ya reckon 2nd order L/R at 200?? the jaycar 12's are smooth enough but I dont think first order will cut it,
#6 | |
Doug
#7 | |
*** What if you got a second pair of 8WR's and set them as a 1.5? ie close together vertically on the baffle, with the lower one a first-order low-pass? Maybe enough bass without trying to blend two completely different drivers ... ? Doug
#8 |
"2nd order L/R at 200?? " - I used 1st order at around 150 and didn't have a problem (3mH and 150uF), but 2nd order's only a couple of extra parts, try both...
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#9 |
Hi Peter, that was my initial thought.
OK I'll try first on the woofer, second on the full range ( I have 3mH on the shelf, if I use standard values for the second order and use the 9mH coil I have, then that should be close enough for trial listening. And if I need some top end sparkle I'd add that later
#10 |
Another pair of 8WR's have just appeared on fleaBay (Melbourne).
... if you wanted to try the 1.5 route ... cheers Doug
| Does open baffle suffer from baffle step? | 454Casull | Multi-Way | 15 | 19th May 2012 03:12 PM |
| Open-baffle baffle length | matejS | Multi-Way | 2 | 21st September 2010 04:49 PM |
| Murphy baffle radios [ open baffle ] | keithpeter | Full Range | 10 | 11th September 2007 07:59 PM |
| what effect does baffle have on open-baffle system? | kappa546 | Multi-Way | 6 | 24th January 2006 10:21 PM |
| Australians- what solid timbers for baffle? (open baffle loudspeaker) | tktran | Multi-Way | 13 | 29th November 2004 11:09 PM |
| Page generated in 0.10888 seconds (78.41% PHP - 21.59% MySQL) with 10 queries |
