Good for a dipole midbass array?
Old 12th August 2008, 10:02 PM   #1
Fast1one is offline Fast1one  United States
Default Good for a dipole midbass array?
I was looking at the buyouts on Parts Express and found this driver:
http://www.partsexpress.com/pe/pshow...9-828&scqty=24
*Le: .77 mH
*Impedance: 8 ohms
*Re: 7.5 ohms
*Fs: 40 Hz
*SPL: 85 dB 1W/1m
*Vas: 1.57 cu. ft.
*Qms: 5.07
*Qes: 1.41
*Qts: 1.10
*Xmax: 6.5 mm
What kind of extension could I expect down low in U baffles? These would be Midbass only till around 2-300hz so the c-t-c spacing doesn't concern me...I would probably use 12 per side.
This will be strictly for music (all genres) and I'm trying to decide whether to go with 2-4 large drivers (15s or 18s) in H baffles or two line arrays of midbass drivers...the midrange would be handled by line arrays of 3 inch drivers and tweeters...
Thanks!
-Serg
Old 13th August 2008, 04:07 AM   #2
otto88 is offline otto88  Australia
otto88's Avatar
How low it goes depends on how loud you want it to go.
Xmax of 6.5 mm is good, but an 8 inch with the same Xmax will go a little lower.
Three good dipole designs:
Linkwitz’ Phoenix & Orion, and john k’s NaO all use 8 inch as mids, crossed at the lower end iirc at 100 or 120 Hz.
For bass, the Orion uses 2 * 10 inch (Xmax of 12 mm) to get with EQ flat to about 40 Hz, the Phoenix 2 * 12 inch (Xmax of 12 mm) to get with EQ flat to about 30 Hz.
Google Linkwitz Phoenix for the theory
Cheers
Old 13th August 2008, 08:09 AM   #3
Well I figure with 12 of them per side I can get away with having them play lower...
I atleast want them to play most music (rock especially) without an immediate need of bigger woofers. Down to 50hz or so would be splendid...the don't need to go terribly loud, the room is 10 x 20 feet and extremely "live"...
I am thinking of scrapping the 3 way idea now and just using these woofers with a large array of tweeters and some EQ, thoughts?
Old 14th August 2008, 08:44 AM   #4
otto88's Avatar
If you play rock, you want I think at least 105 dB capability.
You won’t need multiple tweeters.
12 * 6.5 per side would probably do the dB, but with what wiring & ohms, and what amp to drive it?
If you want dipole bass to 50 Hz, why not just parallel two appropriate size drivers, a minimum of 10 inch.
Old 14th August 2008, 10:46 AM   #5
Bluto is offline Bluto  United States
Fastone -
I was wishin I had some dough when I saw those.
Wondered why you were thinking 3 way as they go to 4500 but didn't look at charts if available.
Not sure I'm following you but 12 is pretty tall? Are you going straight up or 2 abreast?
Why not a combo of those with Dayton Neo's and a Sub?
I see all kinds of possibilities.
Bluto
Old 18th August 2008, 07:34 AM   #6
Originally posted by Bluto
Fastone -
Bluto
Just bought them
They are going vertically, stacked up as close as possible they are going to be around 6-7 feet tall each...
Eventually I am going to add dual taped horns for movies...
Cheers!
-Serg
Good for a dipole midbass array?Hide this!Advertise here!
Dipole Ribbon tweeter isolation from dipole mid-woofer array Bent Planars & Exotics 8 29th March 2015 08:45 AM
dipole midbass section vasyachkin Multi-Way 5 17th January 2008 09:22 AM
HPSA1000-R for Dayton HF15 midbass/dipole/line array thadman Solid State 1 11th January 2007 06:27 PM
HPSA1000-R for Dayton HF15 midbass/dipole/line array thadman Subwoofers 0 11th January 2007 05:50 PM
Dipole midbass - best of 3 rick57 Multi-Way 18 26th December 2004 11:07 AM
