I am rebuilding the crossovers on my Dahlquist DQ10's and replaceing the stock caps with "boutique" film caps.
I had always thought that it did not matter which way a film cap was installed but now I'm not so sure? The caps are marked or identified as to which side is the shield and one cap,(Auricap) has a red and bleck lead on it.The others use the shorter lead as the shield. What is the proper direction to place these caps in the circuit?? What are the results if they are "backwards"? |
#2 |
if you change the caps in your speakers and deliberately or accidentally change the capacitor characteristics then you will change the corrections that the manufacturer has engineered into the standard crossover.
It is guaranteed to sound different and this is nothing to do with component tolerances. It is quite likely to sound worse than standard.
regards Andrew T. |
#3 |
FWIW the "shield" should connect to the lowest impedance point, i.e. the amplifier or towards the amplifier. Reverse is likely inaudible. /sreten.
| Capacitor polarity | gabriel/norfolk | Parts | 9 | 28th September 2008 11:56 AM |
| Tweeter Capacitor Polarity Question | omni | Multi-Way | 30 | 19th July 2008 08:53 PM |
| capacitor polarity | dublin78 | Multi-Way | 3 | 6th January 2007 05:48 PM |
| Input Capacitor Polarity | Wynand | Chip Amps | 11 | 29th August 2005 12:10 PM |
| Crossover capacitor question | serengetiplains | Multi-Way | 3 | 30th December 2004 05:14 PM |
| Page generated in 0.08127 seconds (68.73% PHP - 31.27% MySQL) with 10 queries |
