ZRT 2 way versus 2.5 way
Old 11th August 2008, 07:51 PM   #1
s7horton is offline s7horton  United States
Default ZRT 2 way versus 2.5 way
Has anyone built this design? Specifically I'm looking to see what the difference is between the 2 way and the sealed 2.5. I know that the ported 2.5 way will go lower, but I was curious if the sealed 2.5 would be worth building. I do not plan on adding a sub at a later date.
Thanks.
Old 12th August 2008, 07:43 PM   #2
Athlant is offline Athlant  Ukraine
What I recommend is to build this kit on almost same drivers:
http://audiocomponents.nl/speakers/s...f-Mon-SE_3.htm
And as stand mound peerless sls 10'' in sealed enclosure + this amplifier for both (in mono mode) http://www.creativesound.ca/details.php?model=A400
It has all needed regulations. I use myself peerless sls 10'' as a sub and I'm very very pleased with it both for music&movie. I recommend to do a linkwitz transform for it, but for newbie it could be difficult.
Old 12th August 2008, 08:52 PM   #3
Jay_WJ is offline Jay_WJ  United States
I'd prefer Zaph's design to the one in a Dutch website. Based on the xover schematic, the design's xover frequency is much higher than Zaph's 1.7 kHz. The 7" revelator needs to be crossed at 2 kHz or lower for optimal system performance. And the 6600 can handle it with no problem.
And as for 2-way vs 2.5-way, go with 2-way if you don't listen at a very loud volume and don't plan on adding a sub.
Old 13th August 2008, 04:09 PM   #4
Thanks Jay. Could you comment a little more about why you would go with the 2 way if you were not adding a sub?
Thanks!
Old 13th August 2008, 05:40 PM   #5
diyAudio Member RIP
A sealed 2.5 way only goes louder than a sealed 2 way, it does not go deeper.
Basically no plans for a Sub ? double the box size and go vented.
For the 2 way or the 2.5 way.
Again the vented 2.5 way only goes louder than the vented 2 way, it does not go deeper.
Do not listen loud ? go for the 2-way.
/sreten.
Old 13th August 2008, 06:23 PM   #6
I meant exactly what sreten said.
With respect to bass extension,
vented 2-way > sealed 2.5-way
vented 2-way = vented 2.5-way
ZRT 2 way versus 2.5 wayHide this!Advertise here!
Two 6J5 versus one 6SN7 audiobliss Tubes / Valves 11 4th August 2008 10:25 PM
20% versus 43% screen tap ecl8220% Tubes / Valves 10 4th November 2005 09:16 PM
TPP versus PSE. GeirW Tubes / Valves 11 27th November 2004 08:55 AM
Active Sub versus Car sub massive_cranium Subwoofers 0 26th September 2003 02:18 PM
2.5 way versus 3 way Mos Fetish Multi-Way 1 6th April 2003 06:57 AM
Copyright ©1999-2017 diyAudio
