I'm planning a design using scanspeak revelator midwoofers and I'm wondering what the tradeoffs are between the 4ohm and 8ohm versions. Nobody seems to have measured the 4ohms.
Looking at specs I can see higher sensitivity, higher F3 and smaller box required. Assuming I'm happy with the higher F3 and my amp can handle 4ohm load, is there any reason not to use the 4ohm drivers? Are Zaph's distortion measurements relevant for the 4ohm versions as well? Thanks |
| 8ohm speakers 4ohm tap | 5u4 | Tubes / Valves | 1 | 17th April 2009 11:22 PM |
| 4ohm and 8ohm LR4 xo | LukeDuke | Multi-Way | 1 | 17th April 2008 05:09 PM |
| 8ohm or 4ohm? | adrrad | Chip Amps | 5 | 21st October 2007 04:29 PM |
| 4ohm Sub driver to 8ohm Sub amp? | WBFAir | Multi-Way | 10 | 31st March 2007 01:29 AM |
| 4ohm Car Speaker to 8ohm Use? | jdgonko | Car Audio | 1 | 20th April 2006 02:40 AM |
| Page generated in 0.06557 seconds (74.86% PHP - 25.14% MySQL) with 10 queries |
