Closed Thread
Old 11th August 2008, 01:40 AM   #1
GK is offline GK  Australia
Default Parallel driver interaction in a 4-way system.
G’day.
In the not too distant future I’m going to have up and running an amplifier that can deliver huge amounts of power into a very low impedance.
I’m going to need a pair of HiFi speakers to go with it. I have elected to build a fully sealed 4-way 12db/ octave system starting with a 12” woofer.
However, in order to handle the power output of my amp, I’m going to need parallel drivers – two in parallel for each frequency band should do just fine and dandy.
My knowledge on speaker building is rather limited and I have yet to pick up and read a good text on the topic, so I’m just throwing around ideas at the moment with respect to cabinet design and driver placement.
Attached below is a pic showing a few ideas. Shown at A is a conventional 4-way, with B,C and D being different layouts for twin parallel drivers. I’m going for D at the moment mostly because it would look really cool and the box isn’t too high.
What I basically want to know at this stage is if I am heading in the right direction or if there are any problems with interaction between parallel drivers, which would make these deviations from the conventional 4-way either a failure or waste of time.
Glen
Old 11th August 2008, 01:58 AM   #2
tinitus is online now tinitus  Europe
"A" is the only one that makes sense, but I would "limit" to 3way, its hard enough
With your designs there is a bit of issue with the listening-height
Old 11th August 2008, 02:01 AM   #3
Or like this
Old 11th August 2008, 02:05 AM   #4
Originally posted by tinitus
Or like this
Ok, but that's not too far away from my "D". I still want to do a 4 way though. I like a challenge.
Why the offset of the smaller drivers?
Glen
Old 11th August 2008, 06:04 AM   #5
Default Re: Parallel driver interaction in a 4-way system.
Originally posted by G.Kleinschmidt
G’day.
Edit: I meant 6dB (1st order) crossovers. The 4 drivers I'm looking at have plenty of overlap.
Glen
Old 11th August 2008, 07:02 AM   #6
Making a two way behave nice with 1st order is not so easy,
Trying to to a 4 way is going to be rough.
Having even (linear) amplitude response is going do be difficult.
You would need some sophisticated measuring tools, and prediction programs.
You will probably have issues with the Voice coils of the drivers interacting with the capacitors, and causing resonances that, maybe a zoeble, on the driver will help.
Making a good passive xover, requires more than the basic math to make the circuits. There is no 1 size fits all passive xover, technique.
Normally Multiple tweeters is a bad thing, as they will interfere with each other, and cause a lot of comb filtering.
With most decent drivers you should be OK running 2X RMS if you don't clip your amps.
I have a question:
Do 1st order filters actually sound good? Theres so much overlap, I would imagine a lot of smearing, and overworking of smaller drivers.
Anyhow Go for it if you think you got what it takes. I would go all active xovers and use multiple amps.
Old 11th August 2008, 07:04 AM   #7
Oh PS
I think a Diapollito greater than a 2 way is not normally advised.
Too many xover lobes/nulls.
Old 11th August 2008, 08:13 AM   #8
Let's establish an easy and common convention for discussion speaker designs. W=woofer, M=Midrange, and T=tweeter.
Next there are 2-way and 3-way systems, but there are also half-way systems as in 2.5-way and 3.5-way.
MTM is a common design in which the M stands more for MidBass than just Midrange.
WMTMW is also common and is similar to the Tinitus's design in post #3.
WWMTM is also popular and is similar to the Tinitus's design in post #2.
There are also WWMT designs in which the two 'W' are either running in direct parallel (a 3-way system), or are running in a 1.5 setup where you have one full time bass and one low bass. In a sense, the 1.5 is like a 3-way with a built in Subwoofer. So, actually, the last example would be referred to as a 3.5-way system.
Look at this design -
http://www.zaphaudio.com/ZDT3.5.html
This is extremely popular right now and many people have produced it with good results.
If you are willing to go with one of these more conventional designs, you can get complete design plans for free from the many speaker building sites on the Internet; Zaph Audio being one of the best.
This is built around the reasonably affordable Dayton Reference series, and the crossovers are all designed down to the last detail (and a lot of details it is).
As much as you want to do the design yourself, it is far more difficult than you can imagine, especially for what will end up being sophisticated speakers.
Look at the designs at -
Zaph Audio -
Humble homemade HiFi -
http://www.humblehomemadehifi.com/
Troel Gravesen -
http://www.troelsgravesen.dk/Diy_Lou...r_Projects.htm
Zilla Speakers -
http://www.zillaspeak.com/zillaspeakspeakers.asp
I know there are many others, but I don't have them bookmark.
Once place I do know with a wide assortment of proven designs is -
HT Guide - Mission Possible DIY (for discussions)
http://htguide.com/forum/forumdisplay.php4?f=6
HT Guide - Mission Accomplished (for completed projects)
http://htguide.com/forum/forumdisplay.php4?f=39
Pay attention to the -
- Dayton RS WMTW Center & TMWW Mains
http://htguide.com/forum/showthread.php4?t=15323
- DA Khanspire - An RS150/225 WMTMW
http://htguide.com/forum/showthread.php4?t=26309
Here is a link to a final Dayton WWMTM tower design -
- http://htguide.com/forum/showpost.ph...&postcount=537
Those are somewhat similar to what you propose. Also, don't be intimidated by the exceptionally long threads, as some point, usually near the top, the final design is posted - box dimensions, crossover schematic, and frequently photos of the crossovers and completed designs. Also, frequently complete parts lists with prices
I know how strong the urge is to conceive of a pair of speakers and build them, and if you want some economy speakers, you can throw them together a little easier. But, if you want some good speakers you can be proud of, copy an existing and proven design. Especially for a system as complex as you've conceived.
If you search the internet for the Zaph ZDT3.5, you will probably find links to several forums (including this one) where people have done a spectacular job of reproducing this system.
A good 4-way system is difficult, especially the crossovers, but a 2.5-way or 3.5-way system is easier, with fewer complication, and both are popular proven designs with several choices to pick from.
I don't want to be discouraging, but if you are just starting out, it is much too big a job to tackle without help, and the best help is a proven design. Then with each subsequent design you make, you will become better and more informed, and able to take on more of the task yourself.
I know that's not what you want to hear, but if you want good results your first time out, then you need to do it this way.
The next important thing is your budget, even if this is still just in the fantasy stage. If it is $100 to $300, that requires a completely different approach, than if your budget is $500 to $1,000, which in turn is completely different if your budget is over $1,000.
Generally, the lower you budget, the simpler and more uncomplicated the design can be, but also, the more limited the results will be.
Does any of this help?
Steve/bluewizard
Old 11th August 2008, 08:40 AM   #9
Thanks for the replies!
OK, this is along the lines of what I wanted to know.
If the 3-way WMTMW arrangement is common and works well in proven designs, then is there any theoretical reason why a W-M1-M2-T-M2-M1-W would not also work well in an appropriately engineered 4-way system?
Since two tweeters are bad due to interaction, I guess I can use a high power / high sensitivity horn tweeter to compensate???
Glen
Old 11th August 2008, 08:46 AM   #10
Since two tweeters is bad due to interaction, I guess a can use a high power / high sensitivity horn tweeter to compensate???
Glen
Major Polar issues, depending on where you cross over, as well as inherent polar issues from Xover lobes in a (Hyper Di Apolito?).
Closed Thread
Parallel 12AT7 for 2A3 driver? SHiFTY Tubes / Valves 24 31st January 2006 10:47 PM
series vs parallel in a home system myname159753 Solid State 12 30th April 2005 10:15 PM
Page generated in 0.13558 seconds (82.61% PHP - 17.39% MySQL) with 11 queries
