Old 6th August 2008, 03:21 AM   #1
kippo is offline kippo  Malaysia
Default How to setup using Extremis 4 ohm driver in 2-way configuration for car audio
hi,
I have a pair of Adire Audio Extremis 4 ohm driver and wanted to use them for car audio.
Any recommendation of what tweeters to use in a 2-way setup that will blend nicely with the Extremis? Currently what i have in mind are Scanspeak D2904/600000 and D3004/660000 but these tweeters do cost a bomb.
What about making passive crossover for it? or will it be better to use onboard crossover on the amplifier.
thanks
Old 6th August 2008, 11:07 AM   #2
Dan2 is offline Dan2  South Africa
i cant help you with deciding on a tweeter, but as for the crossover, i would use the one on the amp.
the amp has an active crossover on it, which cuts the bass before it gets amplified. this puts less stress on the amp.
plus you can adjust the cutoff frequency easily.
the only thing you will need on a 2-way setup is a capacitor connected in series with the tweeter, so only high frequencies go to it
WTB: Adire Audio Extremis 6.8 b_force Swap Meet 4 11th July 2008 11:03 AM
Centre channel configuration (Extremis & North D28) Shaun Multi-Way 4 24th January 2006 01:05 PM
Extremis 6.8 as a dedicated bass driver SCD Full Range 9 9th January 2006 06:07 PM
Driver/ driver configuration improve soundstage width andy2 Multi-Way 6 16th June 2005 08:47 PM
Page generated in 0.06916 seconds (69.59% PHP - 30.41% MySQL) with 10 queries
