I'm trying to work through this paper, http://www.quarter-wave.com/TLs/Alignment_Tables.pdf ,
a little difficult given my limited maths... First Question, is 'rho' in the formula at bottom of p3 merely standard air pressure, or is Martin using it to deal with stuffing density (or does he just assume a standard value for stuffing density throughout the paper)? (I'm not sure which paper is referred to on p2 when he mentions "page 6 of the "Method Derivation" section") If I understand the paper correctly, then to simplify Martin's 41 pages down to a few lines 1: Choose SL/So 2: Lookup Leff, Dz, Dr (Tables pp10-12) 3: Calculate So/Sd (formula bottom p3) 4: Calculate Lactual (formula p14) 5: Choose offset. How am I going so far?
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#2 | |||
http://www.quarter-wave.com/TLs/Method_Derivation.pdf Quote:
Hope that helps, |
#3 |
Thanks for the prompt reply Martin, good to know I'm on the right track. Daresay I'll have more questions as I get time to read more...
Cheers, Pete McK
#4 |
attached is Martin's table3 in Graph form; the relationship isn't linear, but should be close enough for intermediate values of Qtd and Dz?
#5 |
I've created a simple spreadsheet which make the calculations from Martin's paper easier. It still requires the user to use the lookup tables.
Apparently I can't attach an Excel spreadsheet here If anyone wants a copy send me an email petermckelvie at optusnet dot com dot au
#6 |
Here's an attempt to zip the spreadsheet:
#7 |
Well, I stuffed that up, forgot Martin's Tables use inches...
attached is a zipped update, still enter the inch figures from Martin's tables, but the result will be in meters (& much more sensible...)
| Pathos Classic one | priax | Tubes / Valves | 4 | 19th December 2011 03:29 PM |
| Greening a Classic? | aborza | Solid State | 58 | 4th July 2009 06:14 PM |
| Problem with Classic 8.0b | Ree | Solid State | 1 | 8th August 2008 11:37 AM |
| Classic 16.0 | Lowrider | Tubes / Valves | 38 | 6th August 2008 08:15 AM |
| amorphous paper or Mu-metal paper can use for D/A chips for shielding or not???? | siu sin man tho | Digital Source | 0 | 17th March 2004 12:31 PM |
| Page generated in 0.10675 seconds (78.91% PHP - 21.09% MySQL) with 11 queries |
