Help me align this 15 in a vented enclosure?
Old 3rd August 2008, 03:29 PM   #1
mpmarino is offline mpmarino  United States
mpmarino's Avatar
Default Help me align this 15 in a vented enclosure?
For a while now I've been running (and tweaking) LaScala DIY enclosures under an Altec 902/811 combo. My final intention was to go passive, but I've been holding off because I wanted to make sure that it would sound reasonable using the DCX2496. In other words, I don't want to start dumping boat loads of tweak time and $$ on passive components if the whole thing is going to be unsatisfactory.
I think I've come to the conclusion that it is unsatisfactory. Although the dynamics are amazing, it simply doesn't sound good to me. The issue is definitely (imho) the upper bass trying to make it's way thru that folded horn, and the funny noises that result. I've been everywhere on the xover with all types of alignments.....
Most people say it sounds fine, They aren't hearing what I'm hearing.
So, I think I might want to try a simple vented enclosure a-la Model 19. The woofers I have are built by Eminence to imitate the original K33 Klipsch woofer. The parameters are:
CW1526C cast frame 15" woofer
FS is 26.3, Re is 3.36, VAS is 506.3 Liters, BL is 12.49, QM is 9.93, QE is 0.27, QT is 0.26. Sensitivity is 97 db. Coil is 1 mH.
Pmax is 150 watts. Xmax is 7.15 mm, MMS is 75.5 grams, Cms is 0.486 mm/N
I need to keep things under 5 cubic feet. The enclosures will be close to the rear wall. Vented alignments certainly aren't my forte, and other than just plugging numbers into winIsd and getting the result - I will probably get into trouble.
So, I plugged some numbers into winIsd and here it is. Can it be improved? (of course it can - but how?)
Thanks!
4.5ft^3 / Ql=7 / 2 X 3" vents 7" long
Crazy Yankee.
Old 3rd August 2008, 03:47 PM   #2
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Default 1/2
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 3rd August 2008, 03:49 PM   #3
Zen Mod's Avatar
Default 2/2
lalala
Old 3rd August 2008, 04:02 PM   #4
mpmarino's Avatar
Choky, You must have had that ready - you mind reader
Thanks!
Looks like WinIsd has similar results to that software. The second one is too big, although it would be nice. Do you think something slightly larger than the first one would be adequate 'in room' for music?
(I don't think 'small' OB is going to give me the impact I am looking for - as I suggested earlier in a different thread)
EDIT and OT:
Lookie looky at the Tuner I found at the Crunchville dump yesterday. It was a 220v unit and I just stuffed a 110 >220 trafo that I had on the floor in the case - walaaaa!
supposed to be a wiked nice tuner...
Crazy Yankee.
Old 3rd August 2008, 04:31 PM   #5
Zen Mod's Avatar
Thanks!
EDIT and OT:
tuner for sissies ........ too much knobs
now I have few issues with my net connection ( too slow) , but soon it works as usual , I'll send ya that proggie I'm using .... so play with it .
of course - completely legal , as soon you buy me a beer ( or it was bear ........ dunno )
Old 3rd August 2008, 04:48 PM   #6
Zen Mod's Avatar
give me proper mail addy - not that gmail #$!$$$$$$@%^^^&!%%@%! thing !!
where I can send you rar or zip file
it bounced back
o, how I hate those web mail dreks!
Old 3rd August 2008, 05:37 PM   #7
mpmarino's Avatar
Yeah - but it's the only thing that makes it to a Serb from a Yank.....
edit: Two knobs is too much??
Crazy Yankee.
Old 4th August 2008, 12:05 PM   #8
R.I.P.
4.5cuft tuned to ~ 30Hz optimises the F-10dB point.
You cannot do much better in a cabinet that size.
The F-6dB point is not compromised, only the F-3dB.
Group delay for ~ 30Hz vs ~ 40Hz is a lot better.
/sreten.
Old 4th August 2008, 07:06 PM   #9
mpmarino's Avatar
Thanks for taking a look.
When I get some time I plan to give it a try - I hope I'm going in the right direction....
Crazy Yankee.
Help me align this 15 in a vented enclosure?Hide this!Advertise here!
Sealed or vented enclosure for the TC-1000 SVC 12'' Davlaf Subwoofers 7 19th November 2006 12:23 PM
MCM 55-2421 Vented Enclosure? cj.9 Subwoofers 2 11th May 2006 06:12 AM
Fb Enclosure tunning Vented webleather Subwoofers 7 28th May 2005 01:27 AM
Vented Enclosure Calculations? mramstedt Multi-Way 3 26th September 2004 06:52 PM
