Problems with FRD Frequency Response Combiner
Old 2nd August 2008, 04:16 PM   #1
FrancoB is offline FrancoB  Europe
Default Problems with FRD Frequency Response Combiner
I'm having problems generating minimum phase from my .frd file.
It's generating errors from the moment I press the 'Extract Minimum Phase' button. The rfcerr.log is growing very rapidly with 'Subscript out of range' errors.
I have the file attached.
I'm running Microsoft Office 2003 SP3.
Anyone?
Maybe someone could generate minimum phase for the file with some other tool and post it back?
Your help is highly appreciated!
Old 3rd August 2008, 02:01 AM   #2
dlr is offline dlr  United States
I just downloaded your file. The first line is not data, it is a *. The frd requires that no comment/non-data lines be in the file IIRC. It also has two extra lines at the end with tabs. These may be a problem also. Be sure all lines are only data lines and try it again.
Dave
Old 3rd August 2008, 09:11 AM   #3
Dave Bullet is offline Dave Bullet  New Zealand
As Dave said.
No whitespace at the beginning or end of the file. I extracted HBT phase fine using your file once I removed the comments and whitespace at the end.
When you load the FRD file - it should show you the start and end frequency. In your case the end frequency was missing because of the whitespace.
David.
Old 3rd August 2008, 09:13 AM   #4
Dave,
Thank you very much for your help.
It solved my problem.
Franco
Old 3rd August 2008, 01:36 PM   #5
Dave,
What's wrong with your Scan Speak 6600 .frd file?
That one doesn't seem to work?
Frank
Problems with FRD Frequency Response CombinerHide this!Advertise here!
Frequency response 2litre Analog Line Level 5 31st May 2006 07:00 PM
opt frequency response nkg Tubes / Valves 3 29th August 2004 06:31 AM
Is my frequency response bad? SimontY Multi-Way 21 2nd July 2004 08:44 AM
Doubts on Phase Response and Frequency Response dumrum Multi-Way 11 5th April 2004 10:39 AM
frequency response of air mikelm Everything Else 8 29th February 2004 07:17 PM
Copyright ©1999-2017 diyAudio
