Old 2nd August 2008, 11:43 AM   #1
Tripmaster's Avatar
Default I have a question for you...
Hi all
My father has given me two SEAS 8” P21REX H282 woofers
http://www.seas.no/images/stories/vi...282_p21rex.pdf
and two SEAS 25 TAF/G tweeters with crossovers.
Does anyone know what these units are like, and if they are OK can recommend a suitable enclosure/crossover?
I think they were purchased from http://www.iplacoustics.co.uk/ several years ago
Trip
Old 2nd August 2008, 11:56 AM   #2
Tripmaster's Avatar
Here are some photos
Old 2nd August 2008, 11:57 AM   #3
Tripmaster's Avatar
and another
Old 2nd August 2008, 11:59 AM   #4
Tripmaster's Avatar
one more
Old 2nd August 2008, 04:44 PM   #5
Tripmaster's Avatar
I plan to pair these speakers with a LM3886 dual mono Chipamp with 2x 300va, twin 25v secondaries. The sensitivity of the woofers are reasonable at 91db.
Would these drivers be suitable for an open baffle design?
I am open to suggestions.
Old 2nd August 2008, 05:19 PM   #6
I have no experience with these loudspeakers at all, but the QTS value of 0.37 seems to make them very suitable for vented boxes (bass reflex boxes). It is quite close to the Q you need for a fourth-order Butterworth alignment. With a fourth-order Butterworth bass reflex design, the -3 dB point would be equal to the free resonance frequency of 33 Hz, if I remember it correctly.
If you put them on an extremely large open baffle or in an extremely large closed box, you get a -3 dB point of about 77.7 Hz. Since you also get a slow bass roll-off below that frequency, you can correct for that electronically to some extent.
With a closed box aligned for second-order Butterworth response, the -3 dB point becomes 63.1 Hz.
Best regards,
Marcel van de Gevel
Old 2nd August 2008, 05:42 PM   #7
I know both these units quite well. The tweeter is smooth-sounding and refined. The P21REX (in my opinion) can be a little difficult to work with in that it is not easy to get decent bass from in it in a ported enclosure, despite encouraging simulations. In a transmission-line design it can be very good - natural, with good bass extension.
Tim.
Old 2nd August 2008, 06:15 PM   #8
Tripmaster's Avatar
Tim.
What would you suggest I do with them? What would you pair with the tweeter?
Old 2nd August 2008, 06:21 PM   #9
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
I'll hazard a guess that they came from an (early) IPL TL speaker kit. If they do, Ivan Leslie may even let you have the cabinet design.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 2nd August 2008, 06:32 PM   #10
PB2 is offline PB2  United States
PB2's Avatar
I believe that they were also used in the Signet SL-280, or perhaps similar versions.
Pete B.
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Capacitor Question /question on cap TunaFish Tubes / Valves 14 12th January 2004 02:23 AM
PS question - tformer question actually breguetphile Chip Amps 2 30th May 2003 01:29 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
Page generated in 0.10780 seconds (79.82% PHP - 20.18% MySQL) with 11 queries
