Can the accuton ceramic tweeters become yellowish on the voice coil "circle" in one place ?
#2 |
Ι have seen it in the recent Athens High End Show, in a pair of Gryphon loudspeakers...
Now I have a link to show what I mean by saying discoloration of accutons... http://www.johneekels.nl/images/MilestonesWS130.jpg http://www.johneekels.nl/images/Milestones%20WS140.jpg The Gryphon dealer told me in the local High End Show that this is normal as the accuton tweeters break in...What do you think? |
#3 |
Being that the cones feel rather like eggshells, it would not surprise me if the adhesive migrated through on strong heating. OTOH, if the adhesive is looking like that I would wonder about long term reliability. I would question the manufacturer as to what is actually discoloring.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#4 |
for me it seems that due to transportation or mechanical shock there is ferrofluid out of the gap on the membrane. I had this experience myself. Best regards Rainer |
#5 |
Thank you for your answers !
What Rainer Weber says sounds logic , as I have observed in all the times the yellowish discoloration appears on the circle that the voice coil touches the ceramic diaphragm and never in the center of the circle. As a result only the accuton tweeters will have this "problem" because they have ferrofluid. Why accuton can't solve this? |
#6 |
Speakerholic
Hi Michael,
I tried to fix the first link but was unsuccessful |
#7 | |
http://www.johneekels.nl/images/Milestones%20WS130.jpg
#8 |
Speakerholic
Thanks Ron
#9 |
Maybe the ceramic is slightly porous?
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#10 |
It has to be as a ceramic. But is not very ok to have a tweeter that costs 200-300-400Euro each and have a brown/yellow circle on it...Not to mention if you have a loudspeaker that costs 10-40000Euro that has an accuton loudspeaker...
Is there any acoustic problem if someone puts more ferrofluid than needed? Also I have found that photos with broken/discoloured accutons are rare. I will attach a burnt tweeter that is discolored too and some broken accuton diaphragms... |
| All-new ultimate 3-way proj. with Accutons and Eton | CeramicMan | Multi-Way | 28 | 29th December 2005 01:15 PM |
| Discoloration inside a tube? | cocolino | Tubes / Valves | 4 | 22nd August 2002 10:12 PM |
| Page generated in 0.11986 seconds (79.27% PHP - 20.73% MySQL) with 11 queries |
