Old 31st July 2008, 07:12 PM   #1
victoriobenatti's Avatar
Default My Audio System (for the time being...)
Hello,
I would like to present here my Audio System.
My loudspeakers consists, each one, for:
- 12" JBL-D123 speaker, for the mid-bass/bass, installed in a sealed cabinet.
- JBL-2426J compression driver coupled to a radial horn of wood, for the midrange.
- Selenium D220Ti compression driver coupled to a radial horn of wood, used for the treble.
In the black box located behind drivers, are the responsible passive components for the alignment and interlacement between the drivers/speaker meet.
My system is bi-amplified.
The sources (CDTransport/DAC and Plays Hard-analog) are connected to a DIY tubes pre-amplifier, which in turn sends the signal to an active 2 way crossover .
This crossover separates bass and subbass, (and also adjust its cutting and intensity using 2 pots) and send this signal to a solid state power that feeds a sealed subwoofer Dahlquist DQ-1w, 12". The subwoofer Dahlquist it is over there in the back from room, on photo where appears only the loudspeaker.
The other part of the crossover frequencies to send a DIY pure triode power amplifier made especially by myself in order to drive this kind of speakers. All technical characteristics of this power, mainly damping, were carefully designed and prepared to exploit the maximum yield of these compression drivers/horns-speaker.
The sources are CDTransport Theta Pearl/DAC Theta Chroma and turntable Thorens TD-126 MKII/SME-3009R/Ortofon MC-20 Super MKII/Former Audio Note AN-S4II.
The pre and the power is tube and the power is pure triode.
The power for passive subwoofer is a Sony TAN-5550 solid state.
The final result is a very clean sound, much balanced tone, very dynamic and with highest resolution.
Victório Benatti
Old 1st August 2008, 02:27 AM   #2
ttan98 is offline ttan98  Australia
Very nice your speakers, a few questions:
1. the x-over frequencies of your speakers
2. the radial horn any info, where you get them?
how do find the sound reproduction?
cheers..
Old 1st August 2008, 02:41 AM   #3
CLS is offline CLS  Taiwan
Where is the Super12 you used previously?
And how does JBL compare to the Wharfedale?
Old 2nd August 2008, 01:15 PM   #4
Hello,
I changed of place the wood horns. Now, the horn of medium is on of the box and the horn of treble is enters of medium and the D123.
The disposal of the horns now is equal the one that is used in the Westlake speakers. They have reason in mounting them of that skill, because thus the voices sound much more "smooths" (not granulate) and natural.
Victório Benatti
My Audio System (for the time being...) victoriobenatti Multi-Way 1 18th June 2008 12:04 AM
First time Home Audio DIY'r...... Yousuredo Multi-Way 36 29th June 2006 01:34 AM
System time memory on pci lagoausente Digital Source 0 13th July 2005 02:39 PM
Off topic: Time to crank up the HT system. Hockey playoffs! Cal Weldon The Lounge 49 5th June 2004 11:59 PM
Page generated in 0.08643 seconds (72.67% PHP - 27.33% MySQL) with 10 queries
