Howdy,
I've put together a design using Focal drivers, specifically the Audiom TLR tweeter and 7W4411 midrange/midbass. Specifactions are as follow: Box Dimensions: 260 X 370 X 460 mm Frequency Responce: 45 to 22000 Hz +/- 2 db and -10 db points 35 and 26000 Hz Crossover Points: 300 Hz and 3700 Hz @ 6 db/octave Should be a great sounding reference bookshelf. Any ideas on the crossover components? Thanks Richy |
#2 |
Do you mean crossover components or crossover design?
Soft Dome |
#3 | |
Hi, that sounds like you are clueless, |
#4 |
Richy:
Crossover design is the most complicated part about designing a speaker. It's not trivial. I recommend you find a published design from a reputable designer if you'd like to build your own speakers. |
#5 | |
crazyhub |
#6 |
#7 | |
Is it a 2 1/2 way? Play around as you see fit, but Focal themselves favour 24db acoustic crossovers. I agree. This normally means second order electrical, so only a couple more parts. Great drivers, lots of potential.
I w isH i cuold typpe bettr |
| need crossover help with focal 7w4411 and td90tdx | mdelrossi | Multi-Way | 5 | 30th July 2008 02:26 AM |
| Raven 2 + Focal 7W4411 2.5 Way? | mgreene | Multi-Way | 3 | 29th October 2007 04:37 PM |
| Looking For Focal audiom 7k2 or focal 7k6411 | jasonyap | Multi-Way | 0 | 29th March 2007 06:46 AM |
| WTB: Focal 7w4411 | TurboFC3S | Swap Meet | 0 | 17th October 2006 06:48 PM |
| A pair of Focal Audiom 7k NOS | kasra | Swap Meet | 2 | 9th March 2006 08:05 AM |
| Page generated in 0.09184 seconds (77.60% PHP - 22.40% MySQL) with 10 queries |
