2way with CA18RNX or ER18RNX
Old 31st July 2008, 03:45 PM   #21
Bricolo is offline Bricolo  France
Bricolo's Avatar
Tiens, un deuxieme grenoblois
Where do you buy the SEAS for a fair price?
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 31st July 2008, 04:00 PM   #22
kaiser38 is offline kaiser38  France
Send a message via MSN to kaiser38
héhé
I'll order at the new distributor for france : website
70€ for one ER18RNX, 40€ for one 27TDFC. About 100€ for the two xover...
Very good price, same as germany !
For the problem with floorstanding cabiner, somebody proposes to me to reduces the width to compensate the height... Is it a good idea ?
thanks
Posted by a computer under Ubuntu Hardy Heron.
Old 31st July 2008, 05:07 PM   #23
Jay_WJ is offline Jay_WJ  United States
The original cabinet width is 9", which is already relatively narrow for a 7" driver. Assuming you use a 1/2" roundover on side edges, You can reduce it to 8". But a 1" difference in width on a tall baffle mainly has an effect on responses above 1 kHz, not much on baffle step.
Old 31st July 2008, 05:17 PM   #24
Originally posted by sreten
A floorstander will afffect BSC which can be ameliorated by making it somewhat narrower, but more likely choose a c/o option for this.
Right. Solving the issue in a crossover is a more effective option.
Old 31st July 2008, 05:56 PM   #25
crazyhub is offline crazyhub  France
My point of view is that if reducing the width doesn't precisely compensate the BS in its both "frequencies place" and level, I see no reason it doesn't really help. All is a mater of what does the speaker acousticaly "undergo" as amount of diffracted frequencies.
Assume a given speaker; an increased baffled version will shift BS at lower fr, a lowered baffled version will shift BS at higher fr. The BS spl loss will remain the same.
crazyhub
Old 31st July 2008, 06:41 PM   #26
Okay. Below are simulation results of the baffle step effects of different baffle sizes. BDS results are very accurate particularly for woofer simulations. As you can see, if we take into account a slight hump at 900 Hz on the original MD14 cab's baffle step, a relative difference in baffle step effect below 1 kHz between standmounting and floorstanding cabs is about 1.5 dB. This must be audible especially if the crossover has full BSC. Also, as shown in the sim, a 1" difference in width of a tall baffle has a minimal effect. The relative difference in baffle step compared to the MD14 response still remains about 1.5 dB.
Old 31st July 2008, 09:11 PM   #27
OK Kim,
The 900hz hump and the related 1800hz dip are directly due to the sizes of the baffle surrounding the woofer.
In your BS sim is the woofer placed as in the intended hole of the MD14 cab?
What would be the effect if you place the woofer close to the top of the baffle on the 8" width floorstanded version?
Thank you.
crazyhub
Old 31st July 2008, 09:19 PM   #28
Hello
Jay, thanks a lot for this simulation
So, the difference between 8" and 9" width is low ! lowest rather than the difference between floorstanding and MD14 enclosure...
Finally, what is the aim of BSC crossover design by John if I can build a different enclosure (less width) without (nearly) difference ?
Lastly, my cabinet will have 32" height, and 2" for spikes, not more !
Jay, I'm interested by your xover, but only if I can have it with 1750hz cut off point...
bye !
Old 31st July 2008, 09:28 PM   #29
Thank you.
Yes, the woofer position is the same as used in the MD14 pre-cut baffle.
Moving the woofer a little upward does not have a notable effect below 1 kHz.
Old 31st July 2008, 09:36 PM   #30
bye !
The purpose of reduced BSC version is different. Note that the reduced BSC amount is greater than 1.5 dB.
I don't understand why you prefer a 1.75 kHz xover point. Using a 1.55 kHz xover point with the 27TDFC (or 27TBFC/G) tweeter helps reduce the system's harmonic distortions in the 1 k to 1.5 kHz range. If you're concerned about the tweeter's power handling issue, you may want to read my blog entries about this issue (Dec 10 and 11th):
http://www.geocities.com/woove99/Spkrbldg/jays_blog.htm
2way with CA18RNX or ER18RNXHide this!Advertise here!
SEAS ER18RNX / 27TBFCG MT 2-way: Listening impressions Jay_WJ Multi-Way 17 25th May 2008 08:03 PM
SR-71's Seas ER18RNX 7" woofer sold out at Madisound :( Other 2-way suggestions? buttfacelicker Multi-Way 39 17th April 2008 08:35 PM
ER18RNX in my Polks M10 License2ILL Multi-Way 4 10th March 2008 12:31 PM
interested in MTM w/810921 and ER18RNX natfin Multi-Way 5 7th January 2008 01:18 AM
