Old 29th July 2008, 02:57 PM   #1
Send a message via AIM to Spasticteapot
Default 2x Seas L21RNX/P + RS52: Good combination?
Recent scrounging has allowed me to procure three mates for my madisound-special Seas L21RNX/P. I'd like to build a three-way active speaker (probably using a DCX2496) using these woofers plus a Dayton RS52 mid and a Hi-Vi RT1-II speaker.
My question is to whether these would be suitable for use with the RS52. Due to the limited number of channels on the DCX2496, I can't equalize the lower woofer differently for a 3.5-way configuration. Is there a configuration for these woofers that will give me really good off-axis performance (+/- 3db at 40 degrees) crossed over at 600-700hz?
Old 29th July 2008, 05:12 PM   #2
sreten is online now sreten  United Kingdom
I'd suggest a passive c/o RS52 to the HiVi tweeter.
More amplifier channels effective.
Then 3 channels including a 0.5 way channel.
/sreten.
Old 29th July 2008, 05:17 PM   #3
/sreten.
Were that a possibility, I'd use a pair of subs.
Old 29th July 2008, 08:07 PM   #4
Zaphs ZDT3 crosses the RS52 at 800Hz with 2nd order acoustic slopes. I think 600Hz may require steeper slopes, as the RS52 may run out of xmax before the dual P21s. Take a look at his comments on the RS52 on the ZDT3
David.
Old 29th July 2008, 08:10 PM   #5
David.
The DCX2496 will allow 8th-order slopes, so I think that won't be a problem. Many people use the L21s to 1.5khz, so the question is not one of frequency response but dispersion.
Old 30th July 2008, 04:09 AM   #6
Jay_WJ is offline Jay_WJ  United States
How will you be sure that you obtain desired acoustic phase tracking between drivers when you use pre-determined eletrical filter slopes? You will need to perform careful simulations using drivers' frequency responses.
Seas Driver H0955 L21RNX/P Mardi Multi-Way 0 27th December 2008 07:06 PM
Good poly mid-woofer (SEAS or Peerless) ch83575 Multi-Way 14 3rd December 2006 10:18 PM
Need Help finding an amp or a good amp sub combination Chawk Car Audio 2 10th November 2005 04:04 AM
Good deals on Seas? bigerik Multi-Way 1 10th December 2004 09:12 AM
CRTs + Subwoofers =? Good combination lpoht Subwoofers 1 19th January 2002 05:39 AM
Page generated in 0.09560 seconds (77.92% PHP - 22.08% MySQL) with 10 queries
