Old 28th July 2008, 05:10 AM   #1
Macpibe is offline Macpibe  Argentina
Send a message via MSN to Macpibe
Default Woofer distortion
I changed the foam surround of my Infinity RS6000 (an acoustic suspension design) 10” polypropylene woofers.
I don’t remove the dust cups and center the dome with shims, but it’s seems to be centered…
Also, I paint the (deteriorated) dust cups with a solution of water and vinylic glue.
When I try those speakers in the sealed enclosure, I can hear a distortion, more in the fast attack of a bass…
I make a mistake to paint the dust caps? Must the dust caps be “vented” with air flow thought this? Or maybe the dome won’t be fully centered whithout the “shim” metod?
Many thanks for your opinions.
Old 28th July 2008, 05:53 AM   #2
lineup is offline lineup  Sweden
lineup's Avatar
In a sealed box I guess you will have to let a little air leak.
We see many times that high end midrange woofers
have a very little hole.
Like somebody has stick a NEEDLE into it.
So I guess you can take NEEDLE with diameter < 1 milllimeter (mm)
and stick it through dust cap.
One tiny small hole .. that's it
lineup
INCREDIBLE 12" woofer-midrange SE friendly, lowest distortion-2khz...MUST READ!!!! Spiritzly Multi-Way 17 29th August 2010 01:05 AM
Dipole woofer nonlinear distortion gainphile Multi-Way 58 13th November 2008 02:54 PM
Woofer distortion Hyldal Multi-Way 9 8th October 2007 12:37 PM
The 8 inch woofer low distortion and active linear 40-700Hz usage quest... leifislive Multi-Way 6 29th May 2004 07:03 PM
Page generated in 0.07027 seconds (66.04% PHP - 33.96% MySQL) with 10 queries
