Hi all
Speaker-room interference is a well investigated trouble area, also a topic exploited in many current and past threads. Triggered by this post, I did a quick and dirty experiment by placing 2 speakers close together and found promising results. Now, taking the idea a bit further, and thinking out loud that one speaker would be better than two in terms of interference and cross coupling, what about having one speaker producing L and R channels (assuming a stereo music material)? There is the option of passively summing L +R at low level stage -easy and cheap- but it has it’s acoustic shortcomings. An idea is to sample both channels at a high sampling rate and feed the outcome to a single amplifier that will drive a single loudspeaker. What do you think about this? Is it a sound idea? Is it implementable? Regards George |
#2 |
Is it not the same as the electrical summing ? Only mechanical / acoustic ? I cannot see the difference and therefore any point at all ... |
#3 |
Sounds like you're going from stereo to mono - ? Or one enclosure with drivers for L + R channels? Then you have no imaging.
If it's a matter of room interference then treat the room. Or have I completely misunderstood your intent?
Soft Dome |
#4 |
Hi Sreten
“Is it not the same as the electrical summing ? “ I do not know if it will end up the same. My 0.000 in electronics does not allow me to know. I was thinking of a multiplexer reading the L then the R, successively, forming a “stream” of instantaneous L1, R1, L2, R2…Ln, Rn (where 1,2…n = successive in time sample numbers). This I think may be done in analoque, like in pseudo-dual channel oscilloscopes, but it certainly could be done better in digital. This all hoping that L , R instantaneous differences will be retained in this electrical signal. If they can not be retained, then null . But if they can be retained, then, this signal amplified, feeds a single speaker. There comes your second question: “Only mechanical / acoustic ?” Will the acoustical outcome of this signal be (or perceived) in a different way from an acoustical outcome of a simple L+R signal? It may be there is no point at all. Yes But in case that there might be a point, Regards George |
#5 | ||||
Sorry sdclc126. I missed your post. We were typing almost simultaneously.
This is what I tried ("I did a quick and dirty experiment by placing 2 speakers close together and found promising results. " in my first post). Quote:
Regards George |
#6 |
Well I thought you had meant you put two speakers next to each other facing FORWARD - definitely no imaging there; but facing in opposite directions for a bipole (not dipole) effect to create stereo imaging by room reflection?
Intuitively I don't see an advantage over the traditional - in fact I see fault in that there WILL be interference due to the fact that the listener will still receive off-axis sound directly from the speaker before the intended room reflections that create the stereo imaging. This could wreak havoc on phase and frequency response and make room treatment even MORE important and more complicated to get right. With my limited understanding of how your idea would be executed electronically I honestly don't see an advantage - it seems like a solution that would just create a new set of problems.
Soft Dome |
#7 |
sdclc126
You may try to implement the idea behind "STEREOLITH" yourself. It is easy. Then report back You also might like to go through this thread. And mind these links: http://www.carlssonplanet.com/downlo...sson_ortho.pdf http://www.youtube.com/watch?v=VC-sxvNzC8I Regardless of my idea, these are enlightening staff Regards George |
#8 |
perhaps if a phase/time component was added to the signals somehow an illusion of imaging could be achieved?
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#9 | |
PeteMcK
I am under the impression that nothing extra should be added. Timing and phase relations of L, R should be preserved if sampling is properly done. If the electronic part was built, this idea could be tested. The problem is that I am not capable to do it (design it). I am only good in soldering Regards George |
#10 | |
| Page generated in 0.11111 seconds (81.50% PHP - 18.50% MySQL) with 9 queries |
