First Project - some advice needed
Old 24th July 2008, 07:02 AM   #11
krikus050 is offline krikus050  United States
I don't think I am going to be very helpful but crossing over in the telephone band is not such a great thing. Our ears are most sensitive in this range. I would suggest a crossover point above 4Khz to eliminate the bad effects of a crossover being in this range. The woofer looks good till 5KHz (in my opinion) if you do think about this. Then the tweeter will definitely be fine with excursion.
Old 24th July 2008, 09:53 AM   #12
Dave Bullet is offline Dave Bullet  New Zealand
The thermal / excursion crosspoint is approx 2600Hz according to my modeling. There's something not quite right with my formulas, as it says the max SPL is limited to 95.7dB... when it is a 96dB/2.83V @ 1m sensitive driver. I might have to check the math.
I would cross minimum 3000Hz at 2nd order acoustic slopes or greater.
David.
First Project - some advice neededHide this!Advertise here!
Hello and advice needed jackpipe Introductions 1 17th March 2007 09:29 PM
Help and advice needed please.... smoothbreed Subwoofers 1 5th February 2007 10:11 AM
First DIY Project - Advice Needed Dan_Sheets Multi-Way 2 8th February 2005 04:49 PM
advice needed jimbones Full Range 6 9th November 2004 07:40 PM
