#21 |
shakers on your chair or couch to achieve the visceral impact via mechanical rather than acoustic coupling. Easier on your elrctric bill, house and your neighbours. A combination of mechanical and acoustic should turn the trick.
moray james |
#22 |
good idea Moray...
Take the Speaker Voltage Test! |
#23 | |
Hi, A big 3 way should have by default 2 of the requirements for slam : good bass extension and good volume capability in the extreme bass. The third, good transient response can be achieved by either sealed or vented alignments. Its not so easy vented, but any downside of this is compensation by the vented arrangements extra volume capability around the port frequency, equivalent to 4 sealed drivers. /sreten.
#24 | |
diyAudio Chief Moderator
#25 |
Might try these http://www.passdiy.com/pdf/el-pipe-o.pdf
#26 |
Here you go. No one mentioned bass horns. Check out the SPL level with 2.83 volts. Guaranteed to pressurize a living room.
Another way to do it is with 10 Dayton DA-175 7" woofers in a line array. Guaranteed to slam you int the chest. http://www.billfitzmaurice.com/T48.html http://www.partsexpress.com/pe/showd...number=295-335 |
#27 | |
Thanks for the suggestion. 10 woofers, whoa. I'll just go with subwoofer route maybe. ![]() Doug |
#28 |
"No one mentioned bass horns"
Back at post #9 I recommended a pair of Labhorns.Even one,corner loaded,will beat a stack of sealed boxes.Before I built the LABhorns,I had eight 12" HSU Research ASW1202 drivers in sealed boxes.They didn't stand a chance against the LABhorn.Ten 7" Daytons won't either... To keep up with horn subs,you will need horns for the rest of the system. Here is a pic of my system before I built a second LABhorn.Midbass is 1/2 space 110 hz expo horn(similar to Altec A7)with Altec 416 driver,midrange is 345 hz Tractrix horn with JBL 2441 driver,and tweeter is Fostex T925a. Will cruise at 110-120 db without breaking a sweat... http://img244.imageshack.us/img244/7739/0000001ix7.jpg |
#29 |
Hi Don,
Your suggestion of horns just reminds me of my postponed project: building a horn-based high-eff system. I have a pair of Fostex H420 wood horns that are mated with JBL LE85 drivers. I'm going to cross them over at 900Hz and am going to add T925a also, but couldn't decide the bass unit yet. I am thinking about several things, but I really don't want anything too large. What about using Madisound BK-20 as bass unit? The lowest end will be only like 50Hz but as my posts in this thread notices, I am concerned about bass slam, not whale's language. Or where can I get those tractrix horns for 15" units? Thanks Doug |
#30 |
I built a pair of thr bk16's a while back,with Fostex ff165K.They were OK ,but slam is not a word I would use to describe them.I wouldn't expect the bk20's to be much better,but I haven't heard them.
I turned the horns myself,but you can get tractrix horns from edgarhorn.com.He also sells a kit horn shell for 15" drivers. The Altec 825/828 (A7 Voice of the Theater)cabinet will also work well,plans are available on the net. A Karlson K15 would be a good choice,too,and has the slam you are looking for. http://home.planet.nl/~ulfman/ Freddyi is the resident guru on Karlsons on the hi-eff speaker forum at audioasylum.com |
| pressure-release cabinet | buggsson | Multi-Way | 3 | 24th December 2007 01:46 AM |
| air pressure in relation to decibels | Clipped | Parts | 2 | 14th August 2006 10:36 AM |
| Sound pressure in time domain | jamikl | Full Range | 6 | 26th March 2006 02:11 AM |
| Sound pressure, is that the same? | destroyer X | Solid State | 17 | 9th May 2004 11:51 PM |
