The attached image shows a "design" speaker. It has a Manger on the top and a GIA ( not available anymore) at the bottom. The
smaller in the middle is only for design symmetry purposes no speaker. Inside the 2,2 meters hexagonal columns is a Voigt tapered pipe - or almost. It is cut off at 85 Hz with 24dB. The Manger crossover frequency is 170 Hz. The cabinet was handcrafted at a joinery in Bulawayo, Zimbabwe, from silver oak wood. ( And finally shipped from Cape Town). An African artist did the engravings according to some traditional patterns found in the ancient town of the Kings near Bulawayo. The finish is Mombasa blue. The system is active and has 3 power amps build in. Dieter F |
#2 |
Is this actually constructed or just a concept?
If the former, why not a photograph? If the latter, is there an aim to this post? How (or why) do you hook up 3 amps to two drivers?
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#3 |
It is a photograph however of one column, background edited in color of the carpet. The third amp drives the Voigt pipe driver it is an 8 inch Dynaudio.
I thought the idea "why diy speakers" has so far missed the design considerations. You won't spent several thousand on drivers and crossover parts and 100 hours or more on work when you can make some thousand bucks in 100 hours and go and buy a speaker. For ex. JBL makes excellent mini monitors active with equalizer for less than 1000 so why diy a shelf speaker? Or, a subwoofer? Just a waste of time and money. Diy makes however sense if you'll get something that is not available anywhere. This one is certainly unique although the tonal qualities of the Manger which covers the significant spectrum of musical sound is not that convincing however the spatial picturing of sound sources is excellent. Dieter F. |
#4 |
...glaub I nett. Viel spass d'mit!
#5 |
Servus Dieter, hava dŽEhre!
I wanna have a totally design-free Manger-recommended circular baffle on Klipsch LaScala. Do you think I can have it done in Nepal? Oliver |
#6 |
Hum...Black Forest is renowned for no design...
but seriously I am into a gong shaped Manger design. The test enclosure made from rings cut from MDF is acoustically very poor. Has anyone made a bronze enclosure? |
#7 |
Do you know the Bamboo?
http://www.hifi-forum.de/viewthread-104-5558.html |
#8 |
Yes. According to my energy-time-domain calculation stuff the baffle diameter must be at least 80 cm to allow the Manger to sit
about 2/3 diameters off the baffle center. 80 cm diameter bamboo? Have not seen such. But I think such stuff should be available somewhere. I am however very poor in any kind of handcrafting. The design is about so: |
| ORIENTED or Not ORIENTED cores for OPT | ja2dhc | Tubes / Valves | 14 | 5th July 2008 12:31 PM |
| Grain oriented silicon steel core data needed | eppidei | Tubes / Valves | 0 | 14th September 2007 02:08 AM |
| First time build help needed budget oriented | sbrunkow | Multi-Way | 1 | 24th October 2006 05:23 PM |
| Manger + Tumult + R-DES = Full Range Speaker | aj_newman | Planars & Exotics | 21 | 1st September 2004 11:16 AM |
| Starter set - PC speakers and amp Music oriented | PatR | Multi-Way | 4 | 27th December 2003 05:31 PM |
| Page generated in 0.10851 seconds (75.22% PHP - 24.78% MySQL) with 11 queries |
