diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Mounting the Neo8 (http://www.diyaudio.com/forums/multi-way/126652-mounting-neo8.html)
fiat79 20th July 2008 01:04 PM
Mounting the Neo8
Got a pair of the Neo8s and finally worked out the CX to my taste, however, these must be the most difficult to mount driver ever! How are most of you doing it?
Brian Bester 20th July 2008 11:59 PM
1. Make a flange (2mm in this case -pardon the poor pic) and mount
2. Rear mount: see example - http://av123.com/component/page,shop...art/Itemid,37/[/url]
Cheers
Brian
fiat79 22nd July 2008 02:07 PM
Thanks Brian! I get the idea, only I don't think my woodworking skills are up to the task. You would think they would make it a bit easier to mount or make faceplates available per the Neo3 tweeter.
I tried making a template and then used that to route an opening in my baffle. I was going for mounting the Neo8 from the rear but the sides of my opening weren't straight, they got a little wavy in places. How are you guys making the nice looking openings I see?
If I had metalworking abilities, I would just fabricate a flange but that's out.
Copyright 1999-2017 diyAudio
