Hi, i need to know the exit angle of the BMS 4552ND to construct an OS waveguide. I asked BMS, but got no answer. I hope that someone here has this information. If not, is there a way to measure it? If that also doesnt work, would you just guess an angle like 5 degree in the hope that it comes close or build a horn with zero degree?
Thanks. |
#2 |
Location: Sitting behind the 'puter screen, in Illinois, USA, planet earth
Hi
Not having a blown one lying around, Via bright flashlight, that one appears to be about a 15 or 20 degree conical taper down to maybe 5/8 inch diameter, past which is the radial summation. A small but very powerful driver to be sure. Best, Tom Danley
Bring back mst3k and futurama |
#3 |
Thanks Tom
That angle surprises me, since i heard that most other drivers are around 5-6 degree. |
#4 |
Can i screw it open and measure diameters with a ruler or will it be damaged by this?
#5 |
Hi
You can remove the drive assembly with the 6 screws at the rear, just be slow and careful. This is not a normal style driver however as you will see when its apart. It's construction, lacking multiple path lengths in a phase plug and starting with a smallish diameter on exit , allow it to produce a diverging wavefront at the final one inch exit which makes it consistent with conical horns like i use or or other horns which have a fast initial expansion. This is not a good driver for a long exponential horn for example. Eye balling it again, it looks to be a conical section about 3 /4 inch long which (peering through the screen) begins at about 1/2 inch dia and ends at 1 inch dia. If you take off the drive assembly, you will be able to measure that inner diameter. Best, Tom Danley
#6 |
Your comment makes me wonder if a OS waveguide will work well with this driver. Well, best thing to do is see for myself.
Thanks for helping me out Tom! |
#7 |
I recently opened one of my drivers and measured the inner geometry of its exit tube. Ill just post the results in case someone is also interested in building an OS waveguide for the BMS 4552ND.
The tube is preceded by a short segment that seems to be of constant area. I cant measure this one without risking to damage the driver. The flared part of the exit tube is 12mm long. Its starting diameter is 20mm and ending diameter is 25mm. This should equate a wall angle of 11,8 degrees. As a sidenote, the change from the constant diameter part to the flared part of the tube is abrupt, so this should allready be a source of HOM, if i am not mistaken. I am curious if other compression drivers have similar abrupt changes in exit flare, so please tell me if you know. |
#8 |
Thanks for the info MaVo, I'm also investigating building a waveguide for this driver.
#9 |
Has anyone tried this BMS adapter on the 4552nd driver? I am wondering if BMS's design might be more acoustically transparent...especially because of the drivers design ....or just more of the same 1" generic adapter blues
BMS Adapter screw thread to 1 3/8" for 1" driver flange - eBay (item 200290174840 end time Dec-09-10 10:25:36 PST) |
#10 |
Radian 950 PB
flesh flash flush |
| Wanted: pair, BMS 4552nd | oeno | Swap Meet | 0 | 20th July 2008 11:59 PM |
| FS - BMS 4552nd Compression Drivers - Brand New (Australia) | Rialb | Swap Meet | 16 | 5th February 2008 09:37 AM |
| Effects of non standard boundary loading a port exit? | ShinOBIWAN | Subwoofers | 4 | 30th July 2006 06:31 PM |
| TL sub - line exit options | Nuuk | Subwoofers | 15 | 20th August 2004 08:33 PM |
| Page generated in 0.12135 seconds (79.96% PHP - 20.04% MySQL) with 10 queries |
