Old 18th July 2008, 10:37 AM   #1
Default Help with mid bass design
Can anyone help me model this driver? (w250-72 attached file)
Ive tried putting the data into winISD 0.60a1 but it wont save the data, and then in to an older version of winISD, but
it came up with inconsistencies.
I want to put 2 drivers into a box (x 2 for stereo) to compliment a LAB12 Sub that gets rolled off at 100Hz 18db/oct
After looking at the graph, I guess I should roll them off at 1.5K or slightly less?
Can anyone help me with dimms for the box?
Old 18th July 2008, 10:38 AM   #2
Old 18th July 2008, 03:15 PM   #3
GM is offline GM  United States
GM's Avatar
Due to the driver's low Qts you'll need to horn load it to properly XO it at 100 Hz. That, or put it in a too large a cab and use digital EQ to flatten it, though of course efficiency/dynamic headroom will suffer.
Anyway, as is, normally you want the cab to be a max flat sealed alignment, so for dual drivers this would be ~10.12 L net with a ~209 Hz F3/Fb. If you want to EQ it down to a ~100 Hz F3/Fb, then increasing its effective Qts to ~0.53 requires ~75.39 L. Of course since this is a very over-damped ~0.35 Qtc alignment as is, you can EQ it to whatever slope it takes to best blend to the XO in-room.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 19th July 2008, 04:18 AM   #4
Thanks GM!
Some questions:
If I wanted to use my drivers in small venues, would a horn like this be useless?
http://www.speakerplans.com/index.php?id=mt122
Would I need any modifications to that design to accommodate my driver?
What would the major differences be between that horn, and a 10.12 L sealed enclosure?
If I made 10.12L sealed enclosure, what would be the most important design considerations?
Old 20th July 2008, 01:09 AM   #5
GM's Avatar
You're welcome!
This is a long throw horn, so probably not going to suit your needs.
Don't know without comparing specs.
Night and day difference in efficiency and off axis response.
Make sure it's airtight.
GM
ACE-bass amplifier design durxter Subwoofers 40 24th March 2011 11:55 PM
Bass enclosure design? Eugenio70 Multi-Way 0 4th April 2008 10:04 PM
My Bass Cab Design sdclc126 Multi-Way 5 25th October 2007 06:08 PM
The best BASS HORN Design . darkm4n Multi-Way 14 27th March 2004 08:14 PM
bass speaker design help dbaudio Multi-Way 0 12th September 2003 12:17 PM
Page generated in 0.08383 seconds (70.52% PHP - 29.48% MySQL) with 11 queries
