Hardwired X/O components on Cu-Clad PCB
Old 18th July 2008, 10:27 AM   #1
clm811 is offline clm811  United States
clm811's Avatar
Question Hardwired X/O components on Cu-Clad PCB
Anyone used blank (copper-clad)PCB material upon which to mount components for passive crossover (G10,FR4 or PTFE Cu-Clad boards)??
It seems to be better than the ubiquitous perf-board,and the copper layer makes a nice groundplane on which to anchor the "star-ground" terminal. I've tried this and it seems to work rather well...
Anyone care to point out any pros or cons of such an arrangement?
-chas
Old 18th July 2008, 11:23 AM   #2
TroelsM is offline TroelsM  Denmark
TroelsM's Avatar
Hi
I donīt think that you need a ground-plane in a passive CO.
One problem could be that a continuous gnd-plane could act as a shorted winding on the inductors? I've never seen any mentioning of this, so maybe I'm wrong.
A piece of wood/MDF would probably work better, be cheaper and stronger.
Regards TroelsM
Need more time...
Old 19th July 2008, 09:50 AM   #3
clm811's Avatar
Default re:shorted winding on the inductors
TroelsM wrote:
I'm not familiar with this. How does this happen and would this be possible, even when the inductors are mounted vertically, and the copper surface is grounded?
(Attached is a photo of the layout before soldering)
-chas
Old 20th July 2008, 12:41 AM   #4
pjpoes is offline pjpoes  United States
Send a message via AIM to pjpoes
If Troels is saying that a copper inductor on the copper groundplane could somehow short out the windings on the inductor, that shouldn't happen, but could I suppose. The wire is insulated, so unless the coating is damaged, it shouldn't ground out and short the coils. If your worried about it, use enough glue to make sure the parts don't touch.
I've done this but not because there was an advantage to it. i did it cuz I have a large amount of them I purchased from China, with nothing else to use them for.
Some people feel that resonances can cause noticeable problems, that the resonances could impact the sound. I've only read one scientific article to support this, the new published work and white paper from Clarity Cap, and I'm not fully convinced based on this one report. The methods seem sound, the metrics well thought out, but I'm not fully convinced their methods are adequate to rule out other possibilities. I also saw nothing to imply that they controlled for other changes in the capacitors besides resonance (What if ESL or ESR changes too). Anyway, if this was the case, its possible that a more solid mechanical ground, such as a block of wood, would fix this issue.
Old 31st July 2008, 02:00 AM   #5
clm811's Avatar
Default mechanical resonances
Some people feel that resonances can cause noticeable problems, that the resonances could impact the sound...Anyway, if this was the case, its possible that a more solid mechanical ground, such as a block of wood, would fix this issue.
I've used hot glue to bond (cascaded) clusters of caps together and I imagine that by gooping a bit more (hot glue over the circumference of the cap), you could effectively damp mechanical resonances. Securing components to the board using "zip-ties" can further stabilize them.
-chas
Hardwired X/O components on Cu-Clad PCBHide this!Advertise here!
double sided copper clad rv1890 Parts 3 20th February 2006 12:30 AM
Hardwired GC problem Sherman Chip Amps 5 13th May 2004 01:23 AM
Large Sheets Of Copper Clad Board. bigparsnip Swap Meet 0 9th July 2003 01:21 PM
Hardwired DAC incl. the DF1704 (SSOP) A 8 Digital Source 4 21st May 2003 09:23 AM
How should I build the Son Of Zen. Hardwired or using PCBs? Erik Johansson Pass Labs 15 1st July 2002 05:24 PM
Copyright ©1999-2017 diyAudio
