The cost to import Alpha 15A's from the US is quite prohibitive. There's not much options locally here except those designed for car subwoofers and they are always stiff, low Qts items.
Then I noticed DJCity is selling 15" woofers with Qts of 0.57. Not as high as the Alpha, but much better than most car subs. Has anyone had the experience in using these woofers on OB? The plan in mind is to build something like Jamo reference. ![]() # Nominal diameter: 15” 376.5mm # Ohms: 8 ohms # Power handling Peak: 200 watts # Power Handling RMS: 100watts # Sensitivity: 97 db # Frequency Range: 52-4500hz # Thiele-Small Parameters # Fs 52.8Hz # Re 6 Ohms # Sd 34.6 sq.mm # Qms 9.9 # Qes 0.60 # Qts 0.57 # Mms 21.9gr. # BL 10.45 Tm # Xmax +/- 5 mm # Le 1.6mH # Ref 97dB
http://gainphile.blogspot.com |
#2 |
You'll have to use a lot of EQ.
#3 |
Check with http://www.audiomarketplace.com.au/
to see if they're stocking the new Exodus DPL-15 from DIY Cable http://www.diycable.com/main/product...roducts_id=684 |
#4 | |
#5 |
available from WES components. pretty cheap too !!
#6 | ||
Jont. "It is impossible to build a fool proof system; because fools are so ingenious." |
#7 |
fortunately I still a pair of the old Jaycar 15" pA drivers qts=.68, sensitivity = 96dB. and very nice sounding mid response to boot.
soon !!! maybe |
#8 |
These P-Audio 15"ers are a good price, with lower Fs,
downside not quite as efficient (use 2/side) and lower Qt... http://www.cannononline.com.au/store...?idProduct=379
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#9 | |
Don't use anyone that ships UPS/Fedex and send them USPS air. I have about 8 B15's NIB I'll let go to clear some space if that'll help. |
#10 |
| Which (small?) bass horn for Coral 12-inchers? | atilsley | Subwoofers | 5 | 10th June 2009 08:02 AM |
| 4 inchers modded within an inch of their lives | Zero One | Full Range | 62 | 1st February 2007 06:21 PM |
| 2 Peerless 8 inchers? | MITMechE | Car Audio | 0 | 4th February 2005 03:27 AM |
| Another new aussie | oztim | Introductions | 7 | 29th January 2005 02:31 AM |
| Page generated in 0.10445 seconds (86.49% PHP - 13.51% MySQL) with 11 queries |
