I'm using veneered plywood on some tiny (14x14x9", tiny) sub-woofer cabinets so I need to make miter joints to keep the cabinets attractive.
Lock-miters will require less creativity in clamping the glue-up so I've used it as an excuse to get a lock miter bit. Assuming I have enough patience to set the bit up right and make all my same-width cuts at the same time on a squared table saw, can I expect any problems getting the top and bottom of the enclosure to fit? |
#2 |
Use slow set yellow glue for starters.
Rest depends on your precision and your tools. I would opt for 45 miter joints on the top and bottom. |
| Chop/Miter Saw Blade Suggestions | wrenchone | Equipment & Tools | 6 | 22nd June 2009 09:54 PM |
| LCD readout - broken ? or bad joints | 3Dgeek | Digital Line Level | 16 | 31st October 2008 11:56 AM |
| Finger joints vs. screw and glue | PRNDL | Tubes / Valves | 35 | 21st November 2006 01:24 AM |
| Joints for enclosures | CrisTUFR | Multi-Way | 14 | 4th June 2004 09:29 PM |
| How to dado angled joints?? | Jer | Multi-Way | 3 | 5th December 2003 04:43 AM |
| Page generated in 0.05312 seconds (78.21% PHP - 21.79% MySQL) with 10 queries |
