Has anyone upgraded the caps in the external crossover?
#2 |
From what? Are they electrolytic or poly?
Soft Dome |
#3 |
infini and wima
#4 |
Sorry - I didn't mean who is the manufacturer, I meant what type of caps are they.
Polypropylene: http://www.partsexpress.com/dayton-m...capacitors.cfm Electrolytic: http://www.partsexpress.com/non-polo...capacitors.cfm If they are electrolytic you can replace with new of the same or "upgrade" to polys - upgrade is in quotes because, though there is much debate about audible differences between crossover components there is little science. Polys have tighter tolerances and last more or less indefinitely; electrolytics tend to degrade in value over time. The larger the value the bigger price difference too. If there are poly caps in the crossovers I wouldn't change them. Brand does not matter, especially the really expensive stuff.
Soft Dome |
#5 |
The crossover is the M5-HP crossover, same as the model 5.
Prefer feedback before I do a parts swap. |
#6 |
Uh - feedback is what I've already given you - you don't need feedback on a particular model - the advice applies to all crossovers.
Have you checked to see what type of caps it has?
Soft Dome |
#7 |
Take a picture and post it. Picture is worth a thousand words, plus I am curious to see another hi end loudspeakers crossover full of 5c parts.
#8 |
Here's the outboard x-over. It resides in-between the preamp and power amp.
#9 |
Oh it's an active XO - thanks for saying so. Don't touch it.
Soft Dome |
#10 | |
what's so active about that? perhaps it's just "biased" with the battery. |
| Vandersteen 2ci crossover repair | olyken | Multi-Way | 1 | 27th September 2008 04:00 PM |
| Vandersteen Quatro driver placement | luvdunhill | Multi-Way | 5 | 23rd June 2007 10:24 PM |
| please Help me build a new sub around the dayton quatro 15 | VisionxOrb | Subwoofers | 15 | 28th January 2005 07:05 AM |
| dayton quatro sonosub | xstephanx | Subwoofers | 14 | 25th November 2004 03:13 AM |
| PE Quatro 15" Sub | jjdche | Multi-Way | 2 | 16th June 2004 05:06 PM |
| Page generated in 0.09715 seconds (74.39% PHP - 25.61% MySQL) with 11 queries |
