#31 |
We know what it's for, thanks.
The question was if the schematic exists? Do you have it? Tx, Mitch |
#32 | |
Some sarcasm ? You want a schematic for a series capacitor with switchable parallel resistors on the output ? You cannot work out the wiring or the values ? /sreten.
#33 |
Indeed.
You didn't answer the guys question and added to what we already know. |
#34 | |
/sreten.
#35 |
You got it... and sorry for the misunderstanding.
#36 |
Agreed: The concept for a 1st order crossover is as simple as it gets. What Vandersteen is doing here with the parallel resistors to adjust the impedance to maintain the proper crossover frequency is also clear.
However, wheezer's pictures shows a bunch of capacitors (2 infinicaps and a few wimas?) with the biasing battery. Call me a dummy, but how does the the biasing battery connect to the capacitors? Why have the extra wimas? Is it to provide a greater capacitance range? If so why not use all infinicaps? Is the battey just biasing the infinicaps or all the caps? How would one go about calculating the proper biasing voltage? Let me apologize right off the bat for my inexperience. I am interested in this 1st order crossover, but my electronic/audio skills are basic as best. Thanks in advance, fteixeira |
#37 |
After some searching, I found this link. A schematic is given which looks very much like the circuit in the M5-HP. Look at the circuit shown in item 5.
See http://www.thlaudio.com/wondrInfinCapmnl.htm wheezer: can you confirm that this is the circuit used? Hopefully, you can pull the PCB out and trace the circuit. Obviously, there are the addition dip switches to set the cross-over frequency. Happy holidays and a prosperous New Year! |
#38 |
Sorry :-(
It's not the HP5 Vandy x-over. |
#39 |
wheezer, did you ever get an answer here? Or replace the caps with better ones?
I have the 5As now but without the inline filters*. If you prefer to keep the inline filters instead of adding a correct-value coupling cap at the input of your poweramps, I suggest you replace all the WIMAs and InfiniCaps with like values of better caps. Probably I'd use MultiCap RTXs ('styrenes) for the WIMAs and SoniCap Platinums for the InfiniCaps. * I had already replaced the coupling caps in my poweramps to achieve an 85Hz filterpoint, and that works well with the 5As. |
#40 |
Howdy Jeffrey,
M5-HP Oh, I gotcha. No, I've not found any info, nor searched any further. Yea, I've seen the pic's of the 5A's. Beauty's Jeff. You've strayed from home? Changing the amp's coupling caps changes the corner frequency of the amp AND at the OPT. This can do the nasty on the OPT. I schlep my Tek. function gen. to the media room when auditioning an amp or changing front end tubes. I've got the process down pretty good. Using the CD's tone of 100Hz and 1KHz is a PITA. Every time I think about changing the caps in the M5-HP, I get cold feet. I have no experience w/speaker caps (AC only). Then the real estate issue. I do love the RTX though. They serve as couplers in my phono stage and RTE in the RIAA. I'm sure someday I'll get around to it. Regards, W. |
| Vandersteen 2ci crossover repair | olyken | Multi-Way | 1 | 27th September 2008 04:00 PM |
| Vandersteen Quatro driver placement | luvdunhill | Multi-Way | 5 | 23rd June 2007 10:24 PM |
| please Help me build a new sub around the dayton quatro 15 | VisionxOrb | Subwoofers | 15 | 28th January 2005 07:05 AM |
| dayton quatro sonosub | xstephanx | Subwoofers | 14 | 25th November 2004 03:13 AM |
| PE Quatro 15" Sub | jjdche | Multi-Way | 2 | 16th June 2004 05:06 PM |
