Vandersteen Quatro crossover
Old 15th July 2008, 04:06 AM   #11
sdclc126 is offline sdclc126  United States
sdclc126's Avatar
Either way it would have helped. "Upgrade" would be to replace worn out parts - still no science behind more expensive of the same stuff.
My work here is done.
Soft Dome
Old 15th July 2008, 04:52 AM   #12
awedio is offline awedio  United States
awedio's Avatar
OK, you can go home now. Not sure that you have done any work, other than to explain how "science" fails to corroborate differences between capacitors... (actually, there are hard measurable numbers to describe the differences in performance, even between similar film caps. How that relates to what we hear is a bit tougher to quantify.
Now, let's roll up our sleeves:
First of all, that 9V battery is indeed a "bias" battery. It keeps the caps "formed" by biasing them up by 9V. This is not an active XO.
Second of all, this is NOT the speaker crossover. This is a 100Hz high-pass filter that does its work at line-level.
I'm not sure I would expect really big changes by swapping out caps in here. The InfiniCaps are quite good, not the $0.05 parts our skeptic friends were hoping for - these are something like $15 retail. At double that price I would recommend Mundorf Silver/Oil caps, but they are large and you may have a tough time fitting them in. You could bypass the Wimas with silver Mica for not a lot of money or time involved.
"Where is my mind? Where is my mind? Wheeere is myyy mind? Waaay out, in the water, see it swimmin'..." Black Francis
Old 15th July 2008, 05:25 AM   #13
wheezer is offline wheezer  United States
Yup HP filter and a PITA to roll amps into my system.
I have K40 and Gudeman caps of the same value to swap for the infini and wima caps. I figure someone must have tried a parts change, for better or worse.
Old 15th July 2008, 05:43 AM   #14
Pano is offline Pano  United States
Pano's Avatar
Those InfiCaps look like polystyrene. Are they? I like polystyrene caps - they just don't come in large values.
Maybe the red Wimas could be replaced....
Take the Speaker Voltage Test!
Old 15th July 2008, 11:40 AM   #15
R.I.P.
Hmmm.....
A biased capacitor line level crossover ..... 100Hz high pass allegedly.
What is it adjustable for ? levels, frequency or both ?
(edit : Its input impedance matching for the correct frequency....)
$600 a pair ? Hmmm...... and you want to upgrade the components ....
Looks a trifle complicated when this can be achieved by the
input coupling capacitor of most power amplifiers quite easily.
FWIW the capacitors appear to be paralled film types, and you
do not get much better than the large (not value) polystyrenes.
http://www.stereophile.com/floorloud...06vandersteen/
The stereophile review seems to indicate a classic case of lack of
BSC in the 100Hz to 500Hz range and no easy way to passively
fix this (unless the overall subwoofer gain can be adjusted).
I am not prepared to argue the point, they seem to be flawed.
I would set about trying to adjust this, cannot do any real harm.
(unfortunately passive line level BSC down to 100Hz and passive
100hz high pass do not mix very well in the same passive circuit ....)
If the subwoofer overall level can be adjusted the BSC could
simply be included in the power amplifier feedback network,
and to get rid of the box (has to be an upgrade ? ...) you
can also changed the power amplifier input coupling.
/sreten.
Old 15th July 2008, 12:30 PM   #16
luvdunhill is offline luvdunhill  United States
luvdunhill's Avatar
Originally posted by sdclc126
Oh it's an active XO - thanks for saying so. Don't touch it.
Originally posted by awedio
[B]>My work here is done.
well, he confused the original poster into thinking it was an active crossover... I suppose that's work......
Old 15th July 2008, 01:29 PM   #17
sdclc126's Avatar
Active/passive/line level - doesn't matter - design is more important than components in audible performance differences.
Soft Dome
Old 15th July 2008, 01:36 PM   #18
sdclc126's Avatar
"OK, you can go home now. Not sure that you have done any work, other than to explain how "science" fails to corroborate differences between capacitors... (actually, there are hard measurable numbers to describe the differences in performance, even between similar film caps. How that relates to what we hear is a bit tougher to quantify."
Yup - thanks for helping me make my point.
"First of all, that 9V battery is indeed a "bias" battery. It keeps the caps "formed" by biasing them up by 9V. This is not an active XO."
Doesn't matter - it's still a filter/XO and expensive components won't make any audible difference.
"Second of all, this is NOT the speaker crossover. This is a 100Hz high-pass filter that does its work at line-level."
See response above.
"I'm not sure I would expect really big changes by swapping out caps in here."
Sounds like we're on the same page here.
Soft Dome
Old 15th July 2008, 01:38 PM   #19
luvdunhill's Avatar
my point is that you couldn't even identify the proper design.
Old 15th July 2008, 03:33 PM   #20
sdclc126's Avatar
And my point is your point is irrelevant, as was my error. Wheezer's question was:
"Has anyone upgraded the caps in the external crossover?" My "point" was he'd be wasting his money.
Soft Dome
Vandersteen Quatro crossoverHide this!Advertise here!
Vandersteen 2ci crossover repair olyken Multi-Way 1 27th September 2008 04:00 PM
Vandersteen Quatro driver placement luvdunhill Multi-Way 5 23rd June 2007 10:24 PM
please Help me build a new sub around the dayton quatro 15 VisionxOrb Subwoofers 15 28th January 2005 07:05 AM
dayton quatro sonosub xstephanx Subwoofers 14 25th November 2004 03:13 AM
PE Quatro 15" Sub jjdche Multi-Way 2 16th June 2004 05:06 PM
