Hallo,
I´m new in this Forum and I plan to construct a new speaker project. I plan a coax two way speaker in a double bass reflex cabinet like Fostex use them or Kondo´s DBR for the Diatone 610. But I found very little information about calculate DBR systems. The speaker I will use will be Beyma or B&C, but I´m open for other driver. |
#2 |
http://www.diysubwoofers.org/prt/dual_chamber.htm
and http://www.claudionegro.com/ are two good places to read through. The point of interest at the second site is under projects / speakers / DCR. A word of caution- if the enclosure that you're going to build involves small chambers and log vents (low tuning in a small box), I would take a pass and go with something more conventional. I did a DCR that way and with the amount of variables & unknowns, especially friction with three vents, I could have built it four times over before getting it right. This is only my experience, though... |
#3 |
I thought in a DBR like Fostex or Diatone 610 by Kondo with 2 ports. I can´t find any calculation for it.
Regards Thorsolar |
#4 |
Speakerholic
Moved to Loudspeakers.
#5 |
The fostex boxes are referred to as Box in a box BIB on this forum. Do some searches.
I don't believe these work any better than a regular vented box.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
| Cheap OB coax? | jimluu | Full Range | 2 | 31st July 2008 03:43 AM |
| TOS to SP/DIF coax | 123chris | Digital Source | 18 | 19th July 2007 04:22 AM |
| Help with design for EV Pro-12B Coax | botrytis | Multi-Way | 29 | 9th May 2007 08:40 AM |
| 10" Coax in OB | inrank | Multi-Way | 27 | 12th September 2006 02:20 PM |
| hum from tv coax | bonsai171 | Everything Else | 17 | 4th April 2004 05:25 PM |
| Page generated in 0.07555 seconds (75.53% PHP - 24.47% MySQL) with 10 queries |
