Thought others might find this of use or interest - here's the pcb layout for a 2 way, 2nd order crossover that I just finished building as part of my first DIY project. Woofer has a zobel, tweeter has resistors to adjust the level. It is designed to mount directly to binding posts spaced 1 inch apart, thus solving the problem of how to secure the crossover inside the cabinet. Overall dimensions are 3.125" x 4.875". The pcb could be used with different component values assuming the sizes didn't change too much, and the tweeter level resistors could be eliminated.
The design was done using Visio. I printed it onto a transparency with my laser printer, running it through twice to get it really dark, and then just straightforward expose / develop / etch using a board pre-coated with resist, doing both images at the same time. I'm pleased with the result. mightydub |
| Crossover for vifa 2 way setup - how can I find out what this crossover is doing? | Tino | Multi-Way | 11 | 17th May 2009 04:21 AM |
| Help me with a crossover. | raypalmer | Multi-Way | 4 | 5th April 2009 01:48 AM |
| Passive crossover into active crossover | hahfran | Multi-Way | 16 | 10th February 2008 06:16 PM |
| Crossover help please :) | Tenson | Multi-Way | 17 | 15th April 2006 09:34 AM |
| Can you hear the crossover point of a speaker with a well-designed crossover? | 454Casull | Multi-Way | 11 | 2nd April 2004 05:48 AM |
| Page generated in 0.05479 seconds (78.29% PHP - 21.71% MySQL) with 11 queries |
