Old 7th May 2009, 10:32 PM   #311
H3D is offline H3D  Netherlands
Hi Studiochap,
I know the partnumber is different. I am curious if anyone knows if it is actually different, or that they just stamped another number on it. I read somewhere it sounds the same.
Old 7th May 2009, 11:02 PM   #312
Shaun is offline Shaun  South Africa
Shaun's Avatar
I'm sticking my neck out here, but I'll say it anyway....
That beryllium tweeter is nothing special!
IMO, it performs no better than any reasonably good modern tweeter. How do I figure that? Well, when I got my NS-1000's, both tweeters were shot. I replaced then with new ones, eventually, but before that I installed a pair of those 4 ohm tweeters that ApexJr sells. They did just fine there, adjusted for correct sensitivity. When I later fitted the new Yamaha tweets I expected to hear a substantial improvement, but that never happened: sound quality was more or less similar.
I believe it is in the midrange driver that all the magic lies and that beryllium, as implemented on the tweeter, yields no significant advantage wrt conventional domes.
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 8th May 2009, 12:49 AM   #313
hugomac is offline hugomac  Australia
There is a difference between the NS-1000's tweeter (JA-0153), they are very similar to the NS-500'S & the NS-2000's but after seeing all the part numbers they are different. I got my tweeters back from Musik Weidergabe in Germany & they're great after burning in, i think it's the best thing to do after trying to source new or used ones. They were $300 Euro & took 2 months but that was with 2 week shipping each way from Australia. Is there any chance that after re-capping these wonderful speakers that there wasn't a huge difference in quality? There sounding soo good at the moment with the B-2 that i kind of don't want to disturb that.
Old 8th May 2009, 05:46 PM   #314
By Shaun:
Respectfully, Shaun: You donīt mention any crossover upgrades, which is THE place to start. Otherwise they will not sound as good as they are able to. The "Beryllium Special" is the absolute lack of coloration,and the ability to reveal just that in the signal chain.You just may be barking up the wrong tree.
As I said in an earlier comment: my old NS1000s did OK. Then I replaced the x/o caps with SCR MKP:s, speakers like new!
Finally I cleaned the level-pots with Kontakt 60, and voila!
Coils and internal cabling were resoldered but kept original.
My take as an experienced warrior in sound engineering, a field where one demands the most accurate tool for the job is:
Finding anything near as good as the NS1000, amplification included, will set you back at least 6000 Euros for a pair.
Such as the ATC SCM 50A.
Soundguy: No Offense, youy have done loads more studio work than I will ever do, but I too want the speaker system to respond and inform when Iīm off the mark .
Old 8th May 2009, 06:51 PM   #315
Shaun's Avatar
Well, I was relating my subjective experience. It may be that the substitute tweet was also not as coloured in the band it was playing in, or the level it was playing at. I'm absolutely convinced of the beryllium mid's performance; I just expected more from the tweeter.
Shaun Onverwacht
Old 8th May 2009, 07:14 PM   #316
Beachmountain
How much did you pay for the Solens & were they difficult to replace?
Old 10th May 2009, 04:49 PM   #317
Here's my pile of upgrade material. Hopefully I can get it in the box.
As my transport's drawer failed yesterday I'm looking for a temporary replacement. Is the Kiss DP1500 internally the same except for the ability to attach it to the computer network?
Old 10th May 2009, 05:02 PM   #318
Hugomac.
I think ELFA charges around 1000 SEK for SCR caps for two x/o:s
Probably cheaper in the UK.
I hope this photo will be included, never done this before .
If not, e-mail me and i will reply.
Not too difficult to swap. Lift out the big electrolytics, leave the sixpack in place, they ARE bitches to get out in one piece....
Solder in the new ones, use melt-glue to secure them.
Best rgds/Conny
Old 5th June 2009, 05:34 PM   #319
Default I know the difference
Hi you all,
I received the tweeters of the NS-500 and there's one big difference: the size They don't fit in the NS-1000. So I will get the original one repaired in Germany.
Besides this I heard the speakers for the first time unmodified and this is very promissing. I'll keep you posted of my findings this weekend. By sunday the new XO should be in.
Old 5th June 2009, 06:46 PM   #320
[/B]
I was very glad to hear you say this, if you are saying the ATC SCM 50 is as good as or better than the NS 1000.
The last time I had the opportunity to listen to the NS 1000s was when they were current on the market - and then, almost certainly not with what would be considered a good amplifier by today's standards.
I did have the opportunity to buy a pair of NS 1000s recently when I was looking for an upgrade in studio monitors for acoustic recordings, including orchestra. The choice came down to these or Klein und Hummel 0300s with subs. After much agonizing I went with the K+H. In the process I learned of a comparison that was done in SLovenia between the ATC SCM50 and the K+H 0410 which is substantially cheaper. The sound from the K+Hs was liked "much, much more", and they are much cheaper. The studio owner immediately replaced his ATC set up with 3 K+H 410s for L,C,R, 2 K+H 0810subs and two K+H 0300 surrounds.
Anyway, it was good to see you mention the ATCs in this context. Now I feel reassured that I am on the right path.
I have yet to hear from anyone who has heard the NS1000s with appropriate amplification compared to the K+H 0410, but that would be a fascinating comparo, especially given the similarity in size and fundamental configuration.
Yamaha NS-8390 crossover frequencies - strange? ray_moth Multi-Way 2 10th April 2012 12:31 PM
Yamaha NS1000 parts and others Beachmountain Swap Meet 1 23rd April 2009 03:25 PM
yamaha ec-1 crossover audiomachines Solid State 1 26th January 2008 11:27 PM
Tweaks vs. insanity (yes, just another thread about tweaks; but there are some links) Rodeodave Everything Else 7 28th February 2007 03:05 AM
Crossover question (refurbing Yamaha PA cab) los_gatos Multi-Way 5 4th January 2004 06:23 PM
Copyright Đ1999-2013 diyAudio
