Looking to build a high end standpoint - Page 2 - diyAudio
Old 10th July 2008, 06:28 PM   #11
sdclc126's Avatar
For "high end reference level" I'd stick with the 2-ways here.
Yes the 7" designs are rather large - a ported ZD5 should work well, with just a taller/deeper enclosure to accomodate the needed volume.
Soft Dome
Old 10th July 2008, 07:22 PM   #12
neil_kaye's Avatar
From the research that i had done i was / am leading towards the ZD5. It's smaller enclosure definitely appeals to me and it has been very well documented.
I will definitely dig through the threads in this speaker, but as a heads up have any of you built this speaker and made subsequent modifications, either in terms of enclosure size and or crossover components.
It appears that Zaph is always spot on in his documentation but it has been a couple ofyears since this speaker was first published.
I remember reading somewhere that Zaph was absolutely insistent on maintaining the 7" baffle width.
Thanks for the great feedback
Old 10th July 2008, 08:59 PM   #13
sdclc126's Avatar
Probably the only person who could improve the ZD5 is Zaph himself.
Several people here have built the ZD5 - the threads should be easy to find.
You mentioned crossover components rather than crossover design - no changes will yield an audible difference, but if cost is easy poly caps are an option, as they will maintain their values over longer periods of time.
Soft Dome
How are NTE Semiconductors from a quality standpoint? OMNIFEX Solid State 5 28th March 2009 12:01 PM
looking for someone to build me a high frequency amp fasterstill Solid State 46 1st September 2007 11:54 AM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Has anyone attempted to build high end studio monitors? Optical Multi-Way 14 9th September 2004 03:00 AM
I Want To Build A Very High Quality A/D Converter BillyJoeJimBob Digital Source 25 6th August 2004 07:40 AM
Copyright 1999-2017 diyAudio
