Cabinet Damping
Cabinet Damping
Old 11th July 2008, 10:59 PM   #11
TerryO is offline TerryO  United States
TerryO's Avatar
Originally posted by MJL21193
I came to this conclusion recently also. Effective bracing splits the surface area of the panels, thereby driving up the amount of energy required to make them resonate. The point is reached where there isn't enough energy to excite the resonance.
Planet10 has been preaching this and I finally caught on.
Yep!
When splitting up the panels you should have your main braces connect several sides, preferably all the panels of the cabinet. Then divide those remaining panels into smaller areas with smaller dimensional braces, say nominal 1X2's into triangular spaces of random sizes. Opposing sides should have different random patterns, as this avoids any harmonic gain or combining at the resonant frequency of the panel. These braces must go from an edge of a panel or a brace, to the same, for effective damping. Actually, this causes the small areas between the bracing to resonate at a much higher frequency, which is more easily damped by the panel itself. Constrained layer constuction, with additional glops, goops or other magic substances can be also used and, in fact, just gluing pieces of leftover or scrap vinyl flooring in between the braces can contribute to peace of mind.
There are so many ways to skin a cat!
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 12th July 2008, 12:54 AM   #12
Willitwork is offline Willitwork  Canada
Originally posted by pjpoes
You will find that tons of bracing, and I can give you some ideas of what I am finding works best, will do the most to deaden the box.
My epiphany in this regard occurred the first time I opened a Matrix series from B&W. The trade-off is larger cabinet size for a given internal volume but most of us can live with that.
Cabinet DampingHide this!Advertise here!
Klipsch - KG5.5 - Cabinet Damping and Crossover Components singlemania Full Range 3 1st September 2010 03:57 AM
Cabinet Damping pjpoes Multi-Way 17 13th April 2007 08:06 PM
TL damping kro5998 Multi-Way 1 19th January 2007 05:43 AM
internal cabinet damping gloop jives11 Multi-Way 6 5th July 2006 09:29 PM
BH 5 damping kyrill Multi-Way 11 22nd June 2004 06:28 AM
