Old 4th July 2008, 01:20 AM   #1
pjpoes is offline pjpoes  United States
Send a message via AIM to pjpoes
Lightbulb Alternative methods for BSC (discussion encouraged)
I have been talking with a well known speaker designer consultant about the design of my next speaker, and began realizing that mine, maybe many others understanding of baffle step compensation is very limited. I thought I would share what he taught me, as it was, at least for me, a new way to do baffle step, and reduces the parts count quite a bit. This also explains why so many crossovers I have seen do not include the normal RL filter for baffle step compensation, but still have a flat response.
this is a traditional crossover with no bsc, and you can see the normal baffle step problem. In fact, because it was measured on a quasi-IEC infinite bafle, its not even showing all of the baffle step you would get with say a 10" wide enclosure.
Here is a traditional RL bsc circuit correctly inserted into the crossover. Of course, other values were changed for a flat response. Also, this includes a tweeter, which the other did not.
Here is the method I was shown for BSC, without a tweeter, for comparison. The difference is no BSC inductor infront with a resistor, but instead, with the first inductor enlarged considerably. I believe this is essentially cascaded crossovers with a 6db at roughly 500hz and then another at 1.5khz at 12db per octave, making for 18db per octave, 3rd order, at the crossover frequency.
This is the new version with zobel and tweeter added, all modified for a flat response. Not perfect, but I threw it together for examples.
Someone once told me that the BSC circuit should be placed in the tweeters signal path, just FYI, that is not so, and will actually create problems. Again, this came from this well known designer, who I will keep nameless because he didn't give me express permission to credit him with this. He told me this method is nothing new, its what many proper designers use, but he didn't see it among the DIY, for whatever reason.
Ok here is where things got interesting for me. I was wanting to use a 2.5 way bsc design. I had read numerous articles and thought, well its a naturally bsc design, why not, its great. I asked about it, read up, and then began this email conversation with the designer. He said, hey wait, no no no. The inductor, he points out, that is on that .5 woofer has to be huge, which will cause a lot larger phase shift and more distortion. It's also more expensive by quite a bit. However, if you use 2 woofers covering the same range, the impedance halves, and the inductor value can be decreased by half. As is shown below.
The only drawback he pointed out was that the woofers need to be of equal distance to the tweeter. really what he was saying was that the distance needs to be less than the wavelength of the crossover point. This mens that, as in a 6.5" midbass, if placed one below the other, then it must be below 1.8khz. One common solution is the MTM configuration, though some don't like its effect on vertical dispersion (Because vertical dispersion is a good thing?).
I know this is a long post, and I may not be stating everything correctly, or even telling you anything new, but it was a revelation for me. I figured it was worth sharing and discussing.
Old 4th July 2008, 02:50 AM   #2
For some reason the cascaded filter topologies were downplayed in the 70's. Perhaps because they were not understood well enough. But it makes a lot of sense in this application. The two driver solution makes sense to reduce crossover part cost and you are also getting some gain there by having two drivers. So the baffle step will not be causing as much total loss of sensitivity I believe.
I still think the Elsinore approach is the most elegant way to deal with BSC but it requires four mid/bass drivers.
Thanks pj, good information.
Old 4th July 2008, 03:30 AM   #3
Except for people who don't have XO design software I have never seen anyone actually use a separate circuit for the baffle step.
Any speaker design methodology is a series of tradeoffs. There is no perfect approach.
For example, an MMT, having both woofers covering the same frequency range is problematic because of the lobing issues you will have unless you go with a low XO frequency as you mentioned. This means steep slopes and a limited choice of tweeters that will sound good crossed at 1.8 kHz. An MTM will get around this but then you have the additional issues of trying to get a good power response vs a 2 way.
Regarding the comment that a big inductor causes more phase shift this just isn't true. The phase shift is caused by the acoustic rolloff, not the electrical rolloff or the size of the components causing the rolloff.
The best way to do the .5 way XO is to use a cascaded XO which AFAIK was first introduced to DIY by Jeff Bagby. In this case you design the crossover for the non .5 way driver with no BSC but the proper rolloffs needed to mate with the tweeter. Then you cascade the .5 way BSC XO off the driver side of the other woofer XO. This way you get the BSC from the .5 way section of the XO but then it transitions to the steeper slope of the other woofer as it goes higher in frequency. This minimizes the parts counts as opposed to designing the additional rolloff needed for the .5 way woofer into a seperate XO for the .5 way driver.
Dennis
Old 4th July 2008, 04:45 AM   #4
biamping, with a 6dB passive line level xover is a good way to go;
all you need to do is adjust the woofer level and BSC is solved...
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 4th July 2008, 05:22 AM   #5
Iain McNeill's Avatar
surely this is only true if your baffle width matches your woofer XO frequency?
GR Koonce has an excellent discussion of MTM and other configurations in the current AudioXpress. Vertical dispersion is a problem all multi-way speakers deal with. As GR discovers, coaxial/triaxial is not a solution.
Old 4th July 2008, 07:59 AM   #6
Pano is offline Pano  United States
Pano's Avatar
Ow. That's complicated....
We start with a normal 2nd order LP, then go to a 3rd order + separate BSC + tweeter, then to what might be a staggered 2nd order, then to 2nd order with Zobel on woofer and tweeter and so on. Easy to get lost.
Would it be easier to consider only the woofer section?
Does 2nd order with staggered inductor values = 2nd order with BSC?
Take the Speaker Voltage Test!
Old 4th July 2008, 11:11 AM   #7
Oversizing the first inductor is the "standard" way of doing it.
A 2.5 way and a 2 way are not the same thing. A 2 way MTM
will have a half value "oversized" inductor but it needs to handle
twice the current so there is no cost saving to be had.
A 2.5 way does not have the c/o point issues of an MTM, and can
be built as a TMM (as can a 2-way, but not often). 2.5 way ties
you into 6dB of compensation, which is inflexible, but if its done
right the advantages outweigh the cost of the "large" inductor.
Well he obviously does not like 2.5 ways, so why not say so.
Its just knocking them, it is the way to do it, it is not wrong.
The 2.5 way can be a cascaded topology as mentioned,
with the 0.5 way inductor after the c/o components.
There is no reason to put a BSC circuit in the tweeter path, not
doing this is not "credit" worthy, its obvious. The only time this
happens is adding an external RL circuit to an unBSC'd speaker.
/sreten.
Old 4th July 2008, 03:13 PM   #8
Well as I said, it was all news to me. I mean, if you look up BSC on the internet, this method doesn't show up ever. Instead, you find article after article on BS and Baffle Diffraction, with talk of an RL contour filter as the standard method. They all use an inductor and resistor.
Yes he does not like 2.5 ways, that is true. He gave me his reason for the bias, the large inductor needed, increased distortion in that woofer, he claims poor integration off axis if not correctly placed, etc. I asked if he preferred a true 3 way to a 2.5 way, and he said yes, that is his preference.
Sreten, I wouldn't say that the 2.5 way is THE way to do it, its A way to do it. What I think I'm saying here, what he was saying, is that there are many ways to do it, and each has its advantages and disadvantages.
As for placing the BSC in the tweeter path, I understand its just plain wrong, but I've seen it done. Not only on posted designs on this forum, but also on others. The home theater forums are the most common place I see this done. Not because they are adding it after the fact, but because they designing based on misconceptions.
Old 4th July 2008, 04:50 PM   #9
Your post read as though 2.5 ways are wrong. They are not.
The way to do a 2.5 way is not to turn it into a 2 way MTM.
The choice between 2.5 and 2 way is a design choice.
/sreten.
http://www.rjbaudio.com/Audiofiles/FRDtools.html
http://www.geocities.com/woove99/Spkrbldg/
http://www.zaphaudio.com/
http://www.rjbaudio.com/projects.html
http://www.troelsgravesen.dk/Diy_Lou...r_Projects.htm
http://www.humblehomemadehifi.com/
http://htguide.com/forum/forumdisplay.php4?f=39
Old 5th July 2008, 04:14 AM   #10
I don't understand why he would think there would be increased distortion in the .5 way woofer compared to a 2 way or an mtm. The .5 woofer and the other woofer are both playing full range in the low frequencies, just the same way it would be in an MTM. or an mmt with both woofers playing the same frequencies. If he is comparing the 2.5 way to a 3 way with a larger woofer, then yes, it is possible that the smaller woofers of the MTM/MMT will be working harder to play the low stuff
I would like to see an example of one of these, can you provide a link?
Thanks and regards,
Dennis
Alternative Painting Methods. MJL21193 Multi-Way 11 22nd September 2009 08:33 PM
First project - getting started. Advice encouraged Jonitus Everything Else 8 24th March 2008 03:17 PM
Discussion of methods for high-current regulated PSU gmikol Power Supplies 8 1st May 2006 11:02 AM
Slow bass myths encouraged mike.e Subwoofers 90 8th April 2005 04:22 AM
Balanced amp methods PWatts Solid State 6 26th June 2003 04:17 AM
Page generated in 0.14670 seconds (85.47% PHP - 14.53% MySQL) with 10 queries
