Suspended Box design idea! - diyAudio
Old 17th March 2003, 05:47 PM   #1
Topgun is offline Topgun  Canada
Topgun's Avatar
Default Suspended Box design idea!
Here is a new design i just thought of using 2 tempests and 4 pr.
It is basically a cube with a driver or pr on every face.
It is suspended from a corner by a frame or cradle using heavy springs or rope.
I don't know if this has allready been done but i thought it migh be an interesting way of doing things.
just wanted everybodys thoughts on this, before i set out to try it, (if i can scrounge up enough money)
Old 17th March 2003, 05:56 PM   #2
A bit like U-vola http://www.synfactory.com/flash/index.html
Only that are satellites (>60 Hz)
Is that all there is?
Old 18th March 2003, 12:23 AM   #3
Wizard of Kelts
diyAudio Moderator Emeritus
Suspending it near a corner would work. If you put it in the middle of a room, you would have no bass.
One thing though. The late, great Paul Klipsch, (of Klipschorn fame), put an acoustic supsension enclosure in a corner on the floor, and then lifted above the floor just a couple of inches. Believe it or not, just lifting the enclosure a couple of inches off the floor actually lessened the bass output somewhat.
Of course, a corner increases the bass output considerably.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
acoustically suspended or not MCPete Multi-Way 15 30th June 2008 11:06 AM
new design idea in the quest of SQ Nemophyle Multi-Way 26 17th January 2006 06:49 PM
Pre-Amp Design HELP / Idea's jleaman Solid State 6 22nd April 2005 09:40 AM
suspended turntables - set-up Timbo in Oz Analogue Source 2 16th June 2004 02:14 PM
suspended deck supermodel Analogue Source 24 30th October 2002 11:58 PM
Copyright ©1999-2017 diyAudio
