Old 2nd July 2008, 08:47 AM   #1
4sfed5 is offline 4sfed5  New Zealand
Default 8"+4"=1" build help please
Ive currently got some Infinity reference 60's and they are on thier way out after 12 years.
im looking at doing a new build using the same layout of 8",4" and tweeter.
Can anyone recommend a matched driver set for this setup?all the different driver modelnumbers is just too much to take in.
i like my music clear and loud, lots of pink floyd and rock music and acoustic/live stuff too.
thanks in advance
Old 2nd July 2008, 09:13 AM   #2
Default Re: 8"+4"=1" build help please
I would definitely suggest higher sensitivity then.
I made the switch and haven't looked back since.
Forget the pretty little toys. Use real drivers..
Old 2nd July 2008, 10:17 AM   #3
Hi, I'd refoam the drivers if they are not broken, /sreten.
Old 10th July 2008, 08:29 AM   #4
unfortunatly one of the tweeters has blown its voice coil and they are no longer available. plus after 12 years im sure the other drivers arent thier best either.
time for something new.
Old 10th July 2008, 09:53 AM   #5
Tweeter substitution is not that difficult. 3 way c/o design is.
Whatever you do, for cost effectiveness the bass units should
be repaired / retained and then matched to possibly new
midranges and tweeters.
Are they rear vented ? possible to retune somewhat ....
An analysis of the current c/o is the place to start.
some critical components may be upgradeable ...
/sreten.
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 06:07 AM
Newbie wants to build a "GainClone-Like" 5.1 Channel Battery Powered Amplifier captain Chip Amps 7 15th October 2004 12:35 PM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 08:42 AM
Page generated in 0.08853 seconds (76.06% PHP - 23.94% MySQL) with 10 queries
