Old 29th June 2008, 07:56 AM   #1
Default manger transducers info
hi all im going to do a project with a manger transducer for mid and highs with a eton 12" hexacone on sub/bass the manger will be run off a passive crossover with the bass /sub active does anyone here have any thoughts or experiance with a setup like this i would also likew to know who distributes them in the usa all and any info would be very much appreciated cheers
Old 29th June 2008, 08:50 AM   #2
I know that E-Speakers.com sold them here in the US (LA, Cali?), but I'm not sure if they still do, as it appears as though the Manger link isn't on the website. You or someone you know should probably give them a call, if you're really interested.
My main question to you is why you'd want to highpass the Manger with a passive xo and go active on the woofer? You'd pretty much be missing out on all the benefits of going active if you did that IMO. Makes no sense to me. With drivers of that expense, I would think it'd be mandatory to 'do it right'..
Old 29th June 2008, 09:05 AM   #3
hi mate i dont want the added expence of using a deqx or such to run it fully active so ill run the bass driver active for now and use a passive crossover to blend the eton into the manger so it only handles mid and high
Old 29th June 2008, 09:23 AM   #4
Any decent 2-way electronic crossover would do just fine, or a DCX2496 if you insist on digital.
Old 29th June 2008, 04:24 PM   #5
No, no no and no !!!!
Why feed the amp signals that will be cut at its output by a crossover afterwards ? The Manger can be driven by a 1st order crossover. So if you use two amps anyway - why not alter the input cap of the amp driving the manger such that it acts as the apropriate 1st order highpass ?
Charles
Old 29th June 2008, 08:00 PM   #6
hi mate i never thought of that ill look into it imgoing to be using a sub plate amp for the bass drivers and an aussie amps nxlsp400 or nvx200 for the manger ill ask anthony what cap is required
Transducers lpoht Multi-Way 8 14th May 2007 12:19 AM
FPS transducers - what to do with them? Spasticteapot Planars & Exotics 14 6th December 2006 11:40 PM
Tactical Transducers punkrokr1701 Everything Else 6 6th November 2006 10:24 PM
I need schemes with transducers of the AD RobertZ Digital Source 2 21st June 2006 10:31 PM
Tactile Transducers seangoesbonk Parts 2 3rd July 2002 12:13 AM
Page generated in 0.10430 seconds (72.23% PHP - 27.77% MySQL) with 10 queries
