With the advent of relatively cheap class D (Tripath) power amp boards ...
for example, see cgi.ebay.com.au/2-15-watt-4ohm-TA2024-D-class-Audio-Amplifier-Board_W0QQitemZ350073355327QQihZ022QQcategoryZ3978 3QQcmdZViewItem ... what is everyone's opinion about a proposal to have an active line array, with individual drivers, or perhaps groups of drivers, powered by these amps. If the aim output was suitably modest in aggregate, the chip amps could be driven well inside their low-distortion zone, and all you would need to arrange would be a good 12VDC supply to each board. (Each board, being stereo, could drive either 2 drivers or two groups of drivers.) Has this been done? A link, anyone? If not yet tried, does anyone like the idea? cheers Doug
A speaker-builder's parable: "That burned down, fell over, then sank into the swamp. But the fourth one stayed up. And that's what you're going to get, Lad, the strongest castle of all." |
#2 |
Can't go wrong with $15 gainclones
http://gainphile.blogspot.com |
#3 | |
Do either of those prices refer to built-up modules? (Presumably I'll need to provide a power supply.) If so, from where can they be obtained? cheers Doug
| BIB thought experiment | Brisso57 | Full Range | 3 | 27th January 2009 03:13 PM |
| Thought experiment: A thousand 12V car batteries in series | bigwill | Everything Else | 6 | 21st June 2007 03:56 AM |
| chip amp for line arrays | zhar | Chip Amps | 5 | 18th November 2006 05:48 AM |
| First experiment with a Line Array | Zreon | Multi-Way | 8 | 21st October 2005 08:36 PM |
| Many Op-Amped Active Crossover Network | Matttcattt | Chip Amps | 2 | 22nd June 2004 09:35 AM |
| Page generated in 0.06371 seconds (79.42% PHP - 20.58% MySQL) with 10 queries |
