Old 26th June 2008, 02:00 PM   #1
jack667 is offline jack667  United Kingdom
Default Hi all - question about Spendor s9e
Hi all,
First post.. hopefully you guys can help me out.
I currently own the Spendor S9e http://www.audiocamp.net/freedata/sookie/work/S9e-1.jpg
The mid and woofer are Spendors own custom drivers, but the tweeter is made by Scanspeak. I was wondering if it's worth (and easy) to change it to a higher end scanspeak tweeter of the same specification?
I've never done anything like this before.. so might not be worth the risk.. but would be interested to hear your advice.
Current speaker specs are as follows..
Description 3 way floor standing loudspeaker
Enclosure type Spendor 3D linear flow reflex
Drive units HF
27mm coated fabric dome, damped vented enclosure
Drive units LF/MF
140mm ep38 polymer cone
Drive units LF 220mm Kevlar® composite cone
Frequency response
40Hz-20kHz ± 3dB on reference axis
Frequency range
-6dB at 28Hz
Dispersion Within 3dB of response on reference axis
Horizontal over 40° arc ( ±20°)
Vertical over 20° arc ( ±10°)
Sensitivity for 1W @ 1m
90dB
Impedance nominal 8 ohms
Impedance minimum 6.0 ohms
Crossover frequencies 350Hz and 4.8kHz
Power handling 30 - 350 watts into 8 ohms unclipped
Harmonic distortion
<1% 100Hz – 20kHz 90 dB @ 1m
Connections
2/3 way gold plated bi-wirable terminals
Magnetic shielding All drive units shielded
Dimensions H x W x D 1005 x 242 x 380mm (39.6 x 9.5 x 15.0in)
Plinth maximum W x D 332 x 400mm (13.1 x 15.7in)
Spikes/feet/stand height 37 ± 3mm
Net weight 36.5kg (80.5lb)
Shipping weight 39.9kg (88.0lb)
Accessories supplied Spikes and lock nuts
Cabinet real wood veneer finishes Cherry, Maple, Rosenut, Black Ash
Thanks all!
Old 26th June 2008, 11:15 PM   #2
anyone?
Old 27th June 2008, 11:22 AM   #3
I understand the tweeter used in that model range is a Seas.
Probably very near to the well regarded Seas 27TDFC.
Changing it is not a good idea ...... unless you redo the c/o.
sreten.
Old 27th June 2008, 05:51 PM   #4
Oh really? I read somewhere it was a scanspeak tweeter.. ?
Old 28th June 2008, 12:56 AM   #5
I read a review that claimed it was a SEAS unit.
http://www.audiofix.com.au/reviews/S9e_HFN_Apr_06.pdf
The dome looks like a 27TFFC, but the motor looks like the T25CF001.
There not much point changing it if you are keeping the old crossover. This SEAS unit is a good tweeter.
Spendor are one of the companies that tend to do use decent drive units and design crossovers properly too.
Anything that you're not happy with in particular?
Old 30th June 2008, 10:20 AM   #6
Some of the older Spendor models, e.g. SP2, used Scanspeak tweeters.
The current models use a Seas, probably built to specification.
Its never a good idea changing drivers in any good speaker.
/sreten.
Spendor D40 amplifier deadhead Swap Meet 24 4th March 2012 09:24 AM
bye bye Spendor, hello...? zix Multi-Way 3 28th February 2004 11:16 PM
Anyone Clone The Spendor Bc1? qwad Multi-Way 11 9th April 2003 02:31 AM
Page generated in 0.10909 seconds (75.77% PHP - 24.23% MySQL) with 10 queries
