diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Tang Band W5-704D 5-1/4" Woofer-- has anybody used this? (http://www.diyaudio.com/forums/multi-way/125326-tang-band-w5-704d-5-1-4-woofer-has-anybody-used.html)
loninappleton 23rd June 2008 06:05 PM
A new thread for this item.
Has anybody used this? It has apparently been around for a while but only recently discussed for using in FR setups.
GM gave an MLTL sim for a cabinet.
I'd be trying to use it stock in some cabinet makings I have.
'Been looking for a project in the 5" range and the newer Fostex
is too rich for my blood.
postalrat 23rd June 2008 06:21 PM
I have a pair of these that have been sitting in their boxes for what seems like a year or two. I'm also interested to hear what kind of results people have been getting from them.
loninappleton 23rd June 2008 06:36 PM
Well, you could always get one out and put it on a board or something,
you know, just for grins.
:cool:
loninappleton 23rd June 2008 07:09 PM
Data sheet
Is there a data sheet for this driver?
I've never navigated the Tangband site with much success.
At PE (Parts Express) the a-b-c measurements look off.
"A" should be the overall flange width. B should be the screw centers
and C is the depth.
But B looks to be 2 plus inches different than A. Perhaps 4 7/8 is the
hole cutout which would make sense. It does not make sense for the
Screw center measurement.
If I did this, It'd be a piece I made with a 5 in hole saw. The cutout for the test box is exactly 5 1/4.
gychang 25th June 2008 02:18 AM
likely will require tweeter?, speaker looks nice.
gychang
loninappleton 25th June 2008 03:02 AM
I'm hoping to sneak by without unless for later tweaks.
However one of those small ones you used with the B20
might have a place.
The driver has been around for a couple years now, but now one
has used it yet.
I'd like to go with a 5 " Fostex but that one is about 5x as much.
augerpro 25th June 2008 04:56 PM
I did a simple little 2 way using these and the Vifa DX25 here: http://htguide.com/forum/showthread.php4?t=28282
Fairly easy driver to work with and doesn't do anything offensive. Bass is decent given the size, but you run out of xmax quickly.
GM 25th June 2008 05:43 PM
Re: Data sheet
Yes, click on 'woofer', then scroll down and click on whichever driver you want.........
GM
loninappleton 25th June 2008 07:17 PM
Re: Re: Data sheet
GM
Ok. Got it and saved it.
145 mm for the screw centers doesn't give me much to bite into.
For this I wanted to use up some pieces from other jobs.
I better check the depth too.
:cannotbe:
dlneubec 25th June 2008 07:24 PM
Here is a ML-TQWT project using the W5-704D in a 2-way.
Dou's
Copyright 1999-2017 diyAudio
