Old 20th June 2008, 07:56 AM   #1
pvl1 is offline pvl1  United States
Default mid for 3 way duty
Does anyone have suggestions for a 5" mid for 3 way 10's for less then $200 each. I cannot find the 5W4254 anymore which I have been using and I considered it a great/clear/detailed/neutral driver - it was a bargain at $100. Crossover points are 300 to 2k. Tweeter is SS9700. Thanks
Pete
Old 20th June 2008, 04:23 PM   #2
sdclc126's Avatar
http://www.zaphaudio.com/5.5test/
Tons of great drivers for under $200.
Soft Dome
Old 21st June 2008, 01:56 AM   #3
p13wh00'
no, I've never used them, but they are legendary!
If your using a metal mid, I wouldn't go above 3".
JJ
Old 21st June 2008, 03:30 AM   #4
Send a message via ICQ to TurboFC3S Send a message via AIM to TurboFC3S
If you're a fan of that driver you can still get the 5w3211b from Zalytron for $107 each.
Old 21st June 2008, 10:04 AM   #5
Default SB midranges?
Thanks for the testing at Zaph. The Seas Nextel looks like what I want. Madisound recommended the SB midrange. Anyone have any info on those - the specs look good and they are a bargain.
Pete
Old 21st June 2008, 08:27 PM   #6
What 10" woofer are you pairing with?
Old 22nd June 2008, 01:12 AM   #7
Default Woofer
The Scan Speak 26W (aluminum cone)
Pete
SE transformer for PP duty? Ty_Bower Tubes / Valves 1 14th September 2008 07:51 PM
Belles Series I for sub duty gp4Jesus Solid State 0 16th November 2006 01:42 PM
What of these for sub duty? leadbelly Subwoofers 25 22nd December 2004 08:31 PM
Page generated in 0.08224 seconds (70.65% PHP - 29.35% MySQL) with 10 queries
