Old 19th June 2008, 08:10 PM   #1
abbster is offline abbster  Sweden
Default Internal volume dimensions
I wonder if there are any tests/theories of how the internal dimension ratios influence the enclosure response? I know the external dimensions are important, such as the front baffle in particular of course, but I cant really find any material of how the air reacts internally. (exept that you will have standing waves and might want to seperate the three main)
Im thinking of building a box that has different ratios externally vs internally, thats why Im asking.
Well, Im happy for any suggestions or links or anything!
thanks,
Old 19th June 2008, 09:27 PM   #2
nigelwright7557's Avatar
Default Re: Internal volume dimensions
thanks,
Most people get around this with acoustic wadding inside the enclosure.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 21st June 2008, 09:09 AM   #3
Svante is offline Svante  Sweden
Svante's Avatar
Yes, there will always be resonance modes ("standing waves") inside a box, regardless of its geometry. The only difference between boxes with different dimensions is the frequencies at which the modes appear.
The way to get rid of the resonance problems is to use stuffing inside the box.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Calculating box dimensions from cubic volume retroman Multi-Way 6 11th July 2009 05:06 AM
Ratios for internal dimensions of speaker box bm_mode Multi-Way 6 18th July 2008 10:06 PM
Actual Internal dimensions of MLTL ttan98 Multi-Way 2 26th February 2008 01:33 AM
Midrange Internal Volume in a 3-Way 69stingray Multi-Way 5 9th November 2005 08:33 AM
What Internal Volume for a guitar cab? Mind Riot Multi-Way 4 24th February 2004 10:55 PM
Page generated in 0.08457 seconds (71.91% PHP - 28.09% MySQL) with 10 queries
