Old 18th June 2008, 11:34 PM   #1
Default Frequency range of acoustic 6 string?
What is the frequency range that an acoustic guitar is most commonly played in?
Is there a 3.5" to 5" speaker that would do well at reproducing acoustic guitar sounds?
Old 18th June 2008, 11:59 PM   #2
I should have mentioned the intended use. I want to try hanging a speaker in front of the sound hole of a guitar for extended times as to induce artificial playing.
I have read a few articles on the subject with varying results. I think it would be a fun experiment.
This is a driver I thought would work off the top of my head.
http://www.partsexpress.com/pe/showd...number=295-358
Old 19th June 2008, 01:25 AM   #3
sdclc126's Avatar
Acoustic guitar (if I'm reading my chart correctly): 80-1300 Hz in round numbers, give or take (fundamentals - not including overtones). So the P.E. driver should do OK but maybe start to roll off at the very bottom.
Soft Dome
Old 19th June 2008, 02:30 AM   #4
This is a cool link!
http://www.geocities.com/dtmcbride/tech/sound.html
It list acoustic guitars at 80 to 880htz
Would the Dayton 4" be able to get down around the 80htz range in a sealed enclosure?
Old 19th June 2008, 08:41 PM   #5
sdclc126's Avatar
Here's what Zaph says:
"This is a great performing 3" driver. The frame is a very nice casting with better than average ventilation. Very smooth, wideband response. Copper appears to be used in the right place in this motor, for very low distortion and no inductive rise. Could be used full range with a breakup notch and a shelving BSC filter, but would be even better paired with a cheap neo tweeter. The cost is not that low for a 3" driver, but considering the performance, value is still very high."
See http://www.zaphaudio.com/smalltest/
Also see graph:
Soft Dome
Frequency range of the human voice & full range center channel speakers jwmbro Multi-Way 31 20th January 2008 04:07 PM
SNR/Dynamic range worsens in low frequency range. percy Digital Source 3 1st June 2006 01:41 PM
Frequency CUT and a HOLE in frequency range... -_nando-_ Everything Else 0 28th December 2005 09:17 PM
Customizing for frequency range? ken.berg Chip Amps 0 28th February 2005 03:17 AM
Page generated in 0.09107 seconds (75.02% PHP - 24.98% MySQL) with 11 queries
