hi
today my first midbass horn got ready. It is painted with poliurethan PU, black satin , which leaves a raw surface. mouth size is 38" / 96cm diameter, and thorat 4" /10cm. Weight is approximately 130kg. Fc is 145hz, and 125hz at half space. I will use it between 150hz and 700hz, with Fane Studio 8M driver, in my next hornspeaker system, full frontloaded, 4 way. Angelo ![]() ![]() more pictures at : Audio Voice Acoustics forum |
#2 |
Dear Lord....beautiful work sir
#3 |
Truly stunning work! Did you turn that monster on a lathe?
#4 |
hi Steve
yes, these horns are made on a big wood lathe. you can see more pictures at my blog Youtube videos : Turning MDF Tractrix Horns |
#5 |
Banned
#6 | |
How are you matching the dispersion of the two horns at 700hz? Do the polar plots match up due to both horns having the same expansion profile? |
#7 | |
#8 |
hello Steve
this is actually , something i am thinking about. One of the main criteria was to place all drivers vertically on axis, to avoid time delay. The mid-bass horn has tractrix expansion. The main goal for the midrange horn is to get the lowest possible coloration. But the coherence of the whole system is important as well. I would like to use a different shape than tractrix for the midrange horn. Maiby something in the middle, between oblate spheroid , and tractrix, with rounded edges, to avoid diffraction . A little bit of both worlds. A flare, that alouds to load down to 700hz, with a mouth size not bigger than 23". I don't know however, if that will create differences in the imaging. If i would use the midrange horn tractrix as well, than certainly there would be no mismatch between the two horns. with Fane Studio 8M driver, full frontloaded, 4 way Looks like you have been cat-ed. it seems there is sort of consensus that it is a good driver for mid-bass horn loading. It is a good starting point for me. I will in the future, however, certainly try out also other drivers. Angelo |
#9 |
Muito bem!
Holy crap those look heavy. When do you want to get started on mine? |
#10 |
Highly impressive - I have been watching your vids on Youtube. Shouldn't you wear respirators during the lathing process and, especially, the sanding, though?
| I Painted my Amp :-o | audiobahnkid592 | Car Audio | 1 | 27th July 2008 01:13 AM |
| how to go from horn response to a folded bass horn design? | paulspencer | Subwoofers | 8 | 4th November 2005 11:44 PM |
| Comments on bass horn sim in horn response | paulspencer | Subwoofers | 38 | 1st November 2005 09:34 PM |
| Page generated in 0.11673 seconds (77.52% PHP - 22.48% MySQL) with 10 queries |
