Old 18th June 2008, 11:18 AM   #1
metal is offline metal  Jordan
metal's Avatar
Default Next Step
I used this software to measure my speakers thiele parameters.
How can I continue with the following:
1. Find the correct dutoff frequency for the tweeter in a 2-way arrangement.
2. Find the correct volume of the box.
3. The alignment of the speaker and tweeter on the panels and best distance between speaker and tweeter.
Old 18th June 2008, 07:40 PM   #2
Iain McNeill's Avatar
rather than duplicate instructions already in existence I would refer you to the wiki's here, the search tool and the greater internet. Zaphs audio site has much of the knowledge you seek as does Rod Elliotts site. Of course there's the AES and the excellent papers by Richard Small and Neville Thiele.
There is also software that will take your parametric data and give you box dimensions and crossover points.
http://www.zaphaudio.com/
http://sound.westhost.com/
http://www.aes.org/
Old 18th June 2008, 08:39 PM   #3
Also, while you have measured the impedance for the drivers, you still need to measure the frequency reponse for each driver mounted in your cabinet.
Once you have these measurements, you can determine the crossover frequencies and design the XO.
Dennis
Step-by-step ambitious first project! Suggestions? ledhed2222 Multi-Way 7 13th August 2009 03:51 AM
Step-by-step guide to building a speaker Richy Multi-Way 5 5th August 2008 12:48 AM
stuffing Mileva: first timer step by step questions schro20 Full Range 7 2nd June 2008 05:49 PM
how to make spherical wood horns, step by step angeloitacare Multi-Way 0 29th May 2007 01:50 AM
LM3886 & LM3876 Step-by-step P2P Guides?? zenon Chip Amps 11 18th November 2006 03:16 PM
Page generated in 0.08450 seconds (67.83% PHP - 32.17% MySQL) with 10 queries
